d series IAC on h22 mani
Old Jun 11, 2006 | 07:40 PM
machine4321's Avatar
Default d series IAC on h22 mani
well i broke down and put the intake mani back on (sold the itbs) so i guess this means its boost time .
i had a D series IAC hooked up for the itbs but i sold my lude one for some reason .
the ports line up and bolt up but it seem to be acting wierd , when i first start the car it revs to 2500 relly qucik then down to 750 ish . after driving it idles at 500.
plus i can hear it opening and closing .
any ideas ?
thanks
Old Jun 12, 2006 | 08:02 PM
just an update . i put a h22 iac on and it didnt want to start with out giving it gas .
plus when the key is on but engine isnt running i can hear the iac humming
Old Jun 13, 2006 | 10:18 AM
any help guys . now when the engine is warm the car wont stay running at all . it dies out at idle
Old Jun 13, 2006 | 10:30 AM
98TypeSH's Avatar
Default Re: (machine4321)
Clean the IACV screen.
Also, what type of intake manifold gasket did you put on ? OEM honda paper ? Sure you dont have a giant vac leak ? manifold bolts torqued up ? All necessary vac lines not ripped and plugged in ?
The hum you hear when you turn your key to the ACC position is the fuel pump priming. Not the IACV.
Old Jun 13, 2006 | 11:15 AM
no this really is the iac, you can feel it "humming and its constant as long as the key is on , the fuel pump is only on for a second , mabye its so dirty its not allowing it to get in the posistion its supposed to bein
i can put my hand over the TB and the car stall instantly , so that rules out any major vac leaks , acctually when i unplug a vac line the car runs a bit better .
i havent cleaned it out yet but i will tonight .
its funny cause any time i touch the gas you can hear the iac slap open and you get the honda suckage sound , it also bucks around if i dont slip the clutch right .
thanks for the ideas
Old Jun 13, 2006 | 12:11 PM
98TypeSH's Avatar
sounding like dirty IACV and screen. Get the carb cleaner and blast that sucker clean!
Old Jun 13, 2006 | 12:26 PM
ill do that tonight when i get home
thanks
i hate over thinking things lol
funny thing is that when i borrowed my buddies iac i cleant it for him lol
but didnt do mine
still not sure why his didnt work at all
Old Jun 13, 2006 | 05:19 PM
found out what it was , im using a f20b lower intake mani and h23 top half ,
well the f20 TB from the factory is completly closed (as in it doesnt assist in the idle )
it had 2 ports that it idle s form and with the h23 top half it only uses one so the engine was figting for air . i adjusted the trottle plate it set it to idle at 750ish and it works great
Modified by machine4321 at 10:21 PM 6/13/2006
Old Jun 13, 2006 | 05:25 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">found out what it was , im using a f20b lower intake mani and h23 top half ,
well the f20 TB from the factory is completly closed (as in it does assist in the idle )
it had 2 ports that it idle s form and with the h23 top half it only uses one so the engine was figting for air . i adjusted the trottle plate it set it to idle at 750ish and it works great </TD></TR></TABLE>
no way any of us would have even guessed that
Old Jun 13, 2006 | 06:16 PM
haha i know , i though iac casue its all i could hear , slapping open and closed. and i sprayed TB cleaner and it all sat at the bottom and didnt get sucked in
solsurvivor
Aug 3, 2004 03:06 AM
solsurvivor
Aug 3, 2004 12:43 AM
jdmh22atch
Jul 12, 2004 02:24 PM
