Where do I go from here
Old Jun 11, 2006 | 07:35 PM
2good4thestreet's Avatar
Default Where do I go from here
I've got a K20a2/K24a1 setup on a 02 EP3 with Toda n2 camshafts and toda springs and retainers and a Tanabe medallion (hyper) My question is I want to boost it but what setup is the best. I still have complete all 3 engines and a few people have told me that the a3 is better with forced induction. I am also torn between the full race stage kit or the cybernation stage 2 or 3 kit. Please any knowledge with merit would help. (Please no info from that guy who runs low 13's with the 2000 Civic EX with just i/h/e) Thanks.
Old Jun 11, 2006 | 08:06 PM
SiR99's Avatar
Default Re: Where do I go from here (QuintinMurray)
So you have a k20/k24 setup already on your car? Shouldnt those be putting out around 240 Whp? But anyways if you want to turbo the motor, go with a custom turbo kit. Just piece together the parts yourself and you will save a bunch of money and will also end up with better quality parts. Your going to have to run more boost on the EP3 engine in order to make the same power on lower boost with the Type S engine. Im not sure how much the price difference between the two engines are, but if the EP3 Si engine is alot cheaper, you should use that, b/c you can always turn up the boost to make the same amount of power. And if your going to be keeping the motor stock, the limit is going to be around 300whp, so it doesnt really matter what motor you have b/c you cant reliably go past 300whp.
Old Jun 11, 2006 | 10:19 PM
dc5RickK20's Avatar
Default Re: Where do I go from here (SiR99)
do you have a k20 head on a k24 block is that what your saying because the k24 has more liters (2.4) so that will be better for boost and if you have toda cams i think thats too aggressive for turbo and your better off running stock cams and valve springs on a turbo setup you cant just turn an all motor car into a turbo car
also if your looking for a good setup i think you should just get a turbo kit like HKS or Cybernation because its going to come with everything you need and you wont have to worry about missing something
Old Jun 12, 2006 | 09:12 AM
Hankish's Avatar
Default Re: Where do I go from here (dc5RickK20)
you have a GREAT turbo set up, minus the cams and semi small cat back. Which 2.4 block are you using? the CRV has the lowest compression, then I think the Accord, then the Element and lastly the TSX...
"BoostedGSR-SI" on http://www.k20A.org ... (he has since blown his ALL STOCK internal motor, but was making OVER 600 Hp!!!! before it blew)
youtube.com
it was me vs. one-fab matt in his turbo GSR coupe
i had 512whp, he had 560whp with help of NOS on stock gsr
http://www.youtube.com/watch?v...civic
i ran 11.2 and he ran 11.5 i believe
STATS: 1995 Honda Civic Hatch K24A1 Block, K20a2 Head . Kpro, 1600cc Inj, One-fab turbo kit T4/GT35R A/R .68 EX, A/R .70 IN
646whp 522tq
Bone Stock K24A1 Block, Bone Stock K20A2 Head, CM Twin Disk Clutch
StOOpified
BLOWN
11.2 @ 129 (467whp)
BUILT MOTOR SOON
http://www.myspace.com/sir2egk
Many people are making OVER 450 HP STOCK 2.0L RSX-S motors as well...
Hope that hepled...
I am planning on a custom turbo set up for my K20A2 EP3, and shooting for 400 Hp and 300 QT.
Hank
Old Jun 12, 2006 | 10:42 AM
ScuDC5's Avatar
as an owner of a CN kit, I can say whole heartedly, Full-Race. CN made a manifold (generic) and downpipe (generic) and called it their kit. Go with something of quality and save yourself a ton of headaches.
Old Jun 15, 2006 | 07:19 PM
dc5RickK20's Avatar
i know this post is kinda old but with the k24 block were you able to put a header on your car? because i think theres some clearance issues
Old Jun 16, 2006 | 11:20 AM
eff sea's Avatar
If you're upping your power, you better to be upgrading your suspension to match.
92accordEX4life
Aug 9, 2008 06:47 PM
SpoonyDC5
22
Nov 6, 2005 08:02 PM
Hatch1990SI
Honda S2000
Sep 4, 2005 09:51 AM
Patron
12
Dec 27, 2002 11:42 AM
