Tranny Swap
Old Jun 11, 2006 | 03:17 PM
K-Spec's Avatar
Default Tranny Swap
I'm trying to remove and swap out my friend's auto tranny with another one and I'm having trouble separating the tranny from the engine block. I removed all the bolts, including the bolts on the rear engine mount.
Old Jun 11, 2006 | 03:58 PM
sj993's Avatar
Default Re: Tranny Swap (khalal538)
You will probably have to remove the passenger side engine mount.
Old Jun 11, 2006 | 04:13 PM
K-Spec's Avatar
Default Re: Tranny Swap (sj993)
ok, i will try that tonite...any other ideas?
Old Jun 11, 2006 | 05:02 PM
gianinline's Avatar
When you do that kind of job... you want to make sure you have all the bolts under and behind the tranny firts, so when the last ones are up to be removed, they can be easily accesed from the top. That is just safer. Be sure to have something ready to hold the tranny when you drop it.
When I swapped my 5sp gear box for another one, I had 3 jacks and 2 big rocks to do the job.
Old Jun 12, 2006 | 08:54 AM
K-Spec's Avatar
Default Re: (gianinline)
thanks for the safety advice
so i was finally able to drop the tranny by removing the engine mount. now my next challenge will be to put a new one in.
V-tecman37
Mar 26, 2008 01:22 PM
GSR_hatch936
Feb 2, 2008 04:34 PM
Alpinestar03
May 11, 2007 04:26 PM
tallblondkid
Aug 11, 2004 01:32 AM
cr-x si
16
Jun 19, 2003 09:13 PM
