exhaust a little too high
so i put on my 3 inch exhuast system, and well it sits a bit too high. high enough to hit the shift rod. i was thinking buying longer exhuast hangers but cant seem to run into any. anybody had this problem? what did you do to solve it? what other options do i have ?
If you need longer exhaust hangers just buy some steel rod that is the same diameter as the hole in the rubber hanger and bend one up and have it welded on.
