having fuel pressure problem im getting too much fuel
motor is running @75pres. at idle i put a aem reg.on it and it will not adjust the pressure dont know what else too do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">u have a clogged return line</TD></TR></TABLE>
sounds good to me
sounds good to me
was there a problem before you did the Adjustable FPR because if not i dont see why the return line would be clogged.
i have had this problem since i did my swap that was about 3months ago and i still havent felt the power of this motor and its making me nuts.and no one can figure this problem out.
yeah, most likelly a clogged return line, some have a problem similar w/ an aftermarket pump thats larger than stock, but normally only see 55-60psi from it, not 75. check for a kink in the return line first.
i checked the return line i dont see any kinks in the line .i pulled the line off the fuel reg. and at the pump and shot air through the line and still didnt do anything
you think it can be in the fuel rail cause the car ran fine with the sohc motor before swap.did a b18c and this is what i have now
