Cylinder compression on S/C Prelude
Old Jun 11, 2006 | 09:53 AM
psi-kik's Avatar
Default Cylinder compression on S/C Prelude
Hi All,
Does anyone know what a normal cylinder compression should be for a 99 supercharged prelude. I thought NA ludes were 185-200ish??...would a supercharged lude have lower compression??
Thanks!!!
Old Jun 11, 2006 | 10:01 AM
GaRn's Avatar
Default Re: Cylinder compression on S/C Prelude (psi-kik)
Those are about the numbers you shoudl expect, what are you getting?
If they are all consistant, then that is what is most important..
Old Jun 11, 2006 | 10:05 AM
psi-kik's Avatar
Default Re: Cylinder compression on S/C Prelude (GaRn)
120-125-125-125
Old Jun 11, 2006 | 10:44 AM
sharkcohen's Avatar
Do it with the engine hot and the throttle plate fully open.
Old Jun 11, 2006 | 12:54 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi-kik &raquo;</TD></TR><TR><TD CLASS="quote">Hi All,
Thanks!!!</TD></TR></TABLE>
a supercharger doesnt change the the dimensions of the pistons
in short, no it doesnt lower compression.
Old Jun 11, 2006 | 02:41 PM
TheAccordGuy's Avatar
That comp means your motor is very weak but still has life though, your comp should be at least at 180 across and even that not to good if the motor has less than 100k. Over 200 for all 4 cylinders is better. I will say that your number are close which is overall more important than anything even though you motor is not as powerful as it should be, it's still not in to bad of shape. I'm assuming you have stock pistons of course. I have a JDm h22 with 10.6 compression and im getting 250 accross all 4 cylinders all stock, just did a rebuild though.
Old Jun 11, 2006 | 03:47 PM
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi-kik &raquo;</TD></TR><TR><TD CLASS="quote">120-125-125-125</TD></TR></TABLE>
It could depend on your elevation and other things..
Old Jun 11, 2006 | 03:52 PM
psi-kik's Avatar
Thanks guys!!
Rotting Prelude
Dec 3, 2017 08:47 AM
Combustion Contraption
53
Nov 18, 2006 09:50 PM
BLUE EH3
Oct 25, 2005 08:29 AM
wutangben
Jun 2, 2003 06:21 PM
stupidfast
Oct 20, 2002 03:50 PM
