sub harness question
Old Jun 11, 2006 | 09:34 AM
lvlossyOak's Avatar
Default sub harness question
well i got a sub harness from a 92 civic d16z6 an when i was stripping the harness i have a few wires left an want to know witch ones i can depin. i know most are ABS wiring but i just dont know witch ones they are. here is a list of the wires an were they are located on the ecu plugs. if any of you can just tell me witch ones to take out. i am planning on doing a b20 in my crx dx but run obd1. please dont rag on me cause of the swap im doing.
thanks, guys
A19- White, Intake control solenoid, Battery Voltage with KOEO
A7-FLR1 fuel pump Grn/BLK, Battery Voltage with KOEO
A8-empty A7 and A8 have the same circurt, so they can be the same
A11- This is EGR Control Solenoid Valve (if the ECU has) Red, N/A
A23,24,26-PG1 ground Black, Power ground, less than 1V
B15-CKP P CKP -P Blu/Green, CKP Sensor input, N/A
B7- Light green, Park/Neutral switch (A/T), Less than 1V in Park or Neutral with KOEO;
5V in Park or neutral with KOER; Battery voltage in all other positions
B11-CYP P CYP -P Orange, CYP sensor input, N/A
B10-VSS vehicle speed sensor Orange, Pulses 0-12V while turning the left front wheel
B8-PSPSW PSP switch Red/Green, Power steering oil pressure switch, 0V KOEO; Battery Voltage
KOER While slowly turning steering wheel
D21 - Blue/Wht, Sensor ground, Less than 1V
D22 - Green/Wht, Sensor ground, Less than 1V
D20 - Yel/Wht, Reference Voltage, About 5V KOEOD15-IAT IAT sensor Red/Yel,
Intake Air Temperature signal, .05-4.5V KOEO(Varies with temperature
D14-PHO2S O2 sensor White, heated 02 sensor Signal,
0.4-0.5V when ignition is turned on; drops to less than 0.1V within 2 minutes
UNKNOWN_MEMBER
Oct 13, 2008 02:24 PM
knightsef-eg
Sep 19, 2008 01:05 PM
VTEC_PRODUCTION
Audio / Security / Video
Jun 9, 2007 05:34 PM
lvlossyOak
Jun 11, 2006 09:01 AM
BlingEG
Apr 4, 2006 03:27 PM
