cam regrind
Old Jun 10, 2006 | 10:28 PM
BlUAc's Avatar
Default cam regrind
just curious my ride is 4th gen accord with a f22b1 head im currently installing milled a 30ths 3 angle valve cut planning on bootsing 7psi am wanting to get my cam regrind need some suggestions my app is daily street driving with some strip on the weekends any help would be helpful
Old Jun 10, 2006 | 10:53 PM
raceACCORDingly's Avatar
rocket motorsport finally made something for the f22
http://www.kteller.com/store/p.../1603
havent heard any reviews on it yet though
Old Jun 11, 2006 | 05:15 PM
gianinline's Avatar
Default Re: (raceACCORDingly)
I would like to know some specs and HP ratings from them. The price is basically the same as F22parts.... wonder if this regrind would be better than a brand new cam....
Old Jun 12, 2006 | 12:05 AM
BlUAc's Avatar
Default Re: (gianinline)
well i just talked to the guy at the machine shop and he wanted to charge 65 snaps he just wanted to know what lift and duration I want
Old Jun 12, 2006 | 08:45 AM
i would lookup the specs on the Delta 272 grind and go with specs similar to it, as its really the only camshaft that has any feedback on it.
Old Jun 13, 2006 | 06:35 AM
mach22's Avatar
Default Re: cam regrind (BlUAc)
Seriuosly your best bet is to just stay with your factory cam. All the so called turbo cams are ground off using a n/a motor cam set up.
Old Jun 13, 2006 | 11:29 PM
BlUAc's Avatar
Default Re: cam regrind (mach22)
ya I know is that I also got a 3 angle valve cut and had it milled a 30ths wont I need an upgraded cam
Old Jun 14, 2006 | 03:45 AM
TouringAccord's Avatar
H-T Order of Merit
no. If you were to upgrade the cam to an aggresive profile, then you would probably want to upgrade the valve springs and maybe the valves. But the 3 angle valve cut and mill work doesn't require an upgraded cam.
hondaboyB18C1
Feb 10, 2006 05:27 PM
gutted-dx
Oct 16, 2005 07:50 AM
