What the heck is up with my Intake Manifold?
Old Jun 10, 2006 | 05:55 PM
B16CivicEX's Avatar
Default What the heck is up with my Intake Manifold?
Hey guys i have a 2000 ex with a b16 swap, i bought the car with the swap all ready done, got the car with no cruise, so was working on getting all the parts. and noticed my intake manifold (witch looks to be stock ) has no place on the bottom side of the drivers side for the cruise control vacume line? i was told the engine is from a SI witch has cruse, so this manifold should have the niple for the cuise vacume line -- Can i 'T' off any where else to for the cruise, Can i connect the crusie vacume canister to any other place. Thanks for the help
Old Jun 10, 2006 | 06:15 PM
B16CivicEX's Avatar
I can attach pics if needed. thx
Old Jun 10, 2006 | 07:28 PM
strictly.business's Avatar
Banned
Default Re: (AirForceB16)
whats the engine code? if at says b16a2, its not the stock i/m. if it says b16a, its out of an sir which didnt have cruise control. expletive cruise control anyway. take it out.
Old Jun 11, 2006 | 05:15 AM
B16CivicEX's Avatar
it says b16a, i have the stuff to install, can i 't' off the vacume line off anything else??? or would i have to change intake manifold?
Old Jun 11, 2006 | 06:28 AM
nutball72's Avatar
cruise control? its a civic not a buick!
Old Jun 11, 2006 | 06:31 AM
sheBangZ's Avatar
Default Re: What the heck is up with my Intake Manifold? (AirForceB16)
you have a civic, prepare for nothing to work and like it. why don't you try tapping the manifold? I don't know much about cruise so I don't know if you could put a t where the fpr line goes back into the intake manifold.
Old Jun 11, 2006 | 06:53 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 9:55 AM 11/16/2006
Old Jun 11, 2006 | 06:56 AM
B16CivicEX's Avatar
yea i drive 60 miles each way to work, i loved having cruise, i dont care if its big and ugly... i just need to find a place to 'T" into for vacume.. the brake booster line is much much larger, and has a check valve, i dont know how much vacume the cruise needs. weird.
Old Jun 11, 2006 | 07:08 AM
B16CivicEX's Avatar
someone said integra cruise does not require vacume? true or untrue?
Old Jun 11, 2006 | 07:45 AM
nota-eg's Avatar
You can T off of the vacuum line that connects to the fuel return instead of Ting into the the brake booster. Easier & cheaper than buying a vacuum plate IMO.
Old Jun 11, 2006 | 07:51 AM
B16CivicEX's Avatar
where can this line be found
Old Jun 11, 2006 | 07:58 AM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirForceB16 &raquo;</TD></TR><TR><TD CLASS="quote">where can this line be found</TD></TR></TABLE>
Answered in your PM, but for future searches:
It's a brass/copper looking that that connects to the fuel rail by two bolts. It has a vacuum line coming out of it that connects to the intake manifold.
That vacuum line should give you sufficient vacuum to run the cruise control & is a cheaper alternative than tapping into the brake booster. (IE: $1 T vs $45 vacuum block.
Old Jun 11, 2006 | 08:01 AM
suspendedHatch's Avatar
Default Re: (nota-eg)
Yes, you can tap off of any other vacuum source to the IM.
"you have a civic, prepare for nothing to work and like it."
What a stupid statement. I have a 93 EG and a 90 Si. On both, every single little thing works fine. You have a Civic, prepare for it to be really easy to fix/replace everything.
Old Jun 11, 2006 | 09:00 AM
B16CivicEX's Avatar
Thanks, i will try to 'T' the fuel vacume line.
Old Jun 11, 2006 | 09:55 AM
Syndacate's Avatar
Default Re: What the heck is up with my Intake Manifold? (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">I would try the brake booster vacuum line.
Dont listen to those chodes who are knockin cruise control. They're the ones who've never driven more than an hour away from home.</TD></TR></TABLE>
Man, don't knock other people if you don't know their story, every fuc8king place I have to go to is more than an hour away ('tis what happens when ur out in the middle of nowhere) and I don't use cruise control, mostly b/c it just leads to **** goign wrong, like accidents 'caused by falling assleep, seen it too many times, wouldn't matter on my car though, if I left it in 5th with the CC on...I'd bog out as soon as the first slight 3º incline came around and I'd stall, so that would be that :-P
In any event, I don't use cruise control b/c it keeps u more alert if u don't, but I can see the need for it, just sayin, don't knock everybody thinkin everybody that hates it doesn't know what it's like to drive long distances..
Old Jun 11, 2006 | 10:27 AM
Archidictus's Avatar
Unceasing Measure
My 93Si's Cruise Control didn't have a vacuum source attached. Then again, I took it off
Old Jun 11, 2006 | 12:47 PM
B16CivicEX's Avatar
thanks
Old Jun 11, 2006 | 05:19 PM
CardDealer's Avatar
Banned
Default Re: What the heck is up with my Intake Manifold? (Syndacate)
Modified by CardDealer at 9:46 AM 11/16/2006
Old Jun 13, 2006 | 04:47 PM
B16CivicEX's Avatar
thx
Old Jun 15, 2006 | 07:42 PM
evil em1's Avatar
still not able to pm but i noticed you were looking for CC parts...I"m actually removing mine so if there is anything you're missin let me know cuz I'll gladly be rid of them...not a fan of cruise myself...but to each his/her own
Old Jun 16, 2006 | 02:14 AM
B16CivicEX's Avatar
do you have # 3 in this digram the check vavle?
Old Jun 16, 2006 | 02:15 AM
B16CivicEX's Avatar
Old Jun 16, 2006 | 07:48 AM
Honda Bull's Avatar
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">"you have a civic, prepare for nothing to work and like it."
What a stupid statement. I have a 93 EG and a 90 Si. On both, every single little thing works fine. You have a Civic, prepare for it to be really easy to fix/replace everything.</TD></TR></TABLE>
Exactly what I was thinking. Everything should work perfectly fine. If not... it needs fixed. Just like any other car.
5exy_Ek
18
Oct 26, 2010 04:56 PM
CSHornet60
Mar 9, 2007 06:00 PM
slim689
Mar 9, 2007 10:19 AM
retriever99
May 21, 2004 11:17 AM
