99 accord keeps on turning off.
Old Jun 10, 2006 | 04:47 PM
accordinglyevil's Avatar
Default 99 accord keeps on turning off.
I drive a 99 accord 4cyl. my problem is that my car keep turning off while i'm driving sometime it scare the **** out of me. it happen to me about 3 or 4 times already on the freeway. luckily it was late at night and the traffic was very light. I know that my year accord have 2 recalls for the ignition. Both of the recall have been corrected by one of my buddy that work at Honda. The last recall was fixed about 3 or 4 days ago. No problem with starting or turning off on me while driving after i got it back. Well today it turn off on me twice, the first time it started right back up and the second time i have to crank it several times to get it to start. What could be the problem? Someone told me it a sign that my dizzy is going bad. how can it test it, if it is my dizzy.
Old Jun 10, 2006 | 04:52 PM
johnnyaccord99's Avatar
Default Re: 99 accord keeps on turning off. (accordinglyevil)
i have the same year accord 4cyl 2dr. and i had the same prob and it just kept getting worse i just fixed it yesterday my rotary button and distributer cap was very corroded! i fixed it and now its not shutting off on me and its real easy to start up
i had tried everything and that finally worked
Old Jun 10, 2006 | 05:07 PM
I change that already it start up quicker but that about the only differnce i can tell on my car.
Old Jun 11, 2006 | 09:04 AM
v4lu3s's Avatar
RTFM
do you have LOTS of keys and other **** on your keychain?
Old Jun 12, 2006 | 01:20 AM
Default Re: (v4lu3s)
nope only my car, 1 house key, n the keyless entry remote.
Old Jun 12, 2006 | 03:49 AM
v4lu3s's Avatar
RTFM
Default Re: (accordinglyevil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordinglyevil &raquo;</TD></TR><TR><TD CLASS="quote">nope only my car, 1 house key, n the keyless entry remote.</TD></TR></TABLE>
just wanted to check sinc i often see worn out ignition switches causing issues like that, usually from too many things on the keychain. I have had at least 3 come into my shop where just slightly wiggling the ignition switch, hitting a bump or some other slight jolt makes the car die....
Old Jun 12, 2006 | 03:55 AM
YeuEmMaiMai's Avatar
i believe that there is a recall for the ignition on the 6th gen cars. take it to your Honda dealer and have them check and if needed perform the recall.
Old Jun 12, 2006 | 11:29 PM
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">i believe that there is a recall for the ignition on the 6th gen cars. take it to your Honda dealer and have them check and if needed perform the recall.</TD></TR></TABLE>
already been done.
Old Jun 13, 2006 | 03:10 AM
take it back and tell them try again since you have the same problems.
Old Jun 13, 2006 | 07:19 AM
sonnieeeeboi's Avatar
are you sure they even did it?
Old Jun 13, 2006 | 07:59 AM
Default Re: (sonnieeeeboi)
my buddy at honda was the one who worked on my car. he came out and told me that he fixed both recall on it.
Old Jun 13, 2006 | 01:12 PM
JimBlake's Avatar
I had the ignition switch recall done on my '98. From what I understand it wasn't related to the electrical part of the switch.
The steel barrel around the lock cylinder had to be reinforced. Somewhere in DOT regs, there's a 'law' that says the key shall not be removeable while the car is running. When the cylinder wears out, the key can be pulled out. THAT'S what the recall was all about.
pastorjeff
Sep 29, 2013 10:35 PM
InOcULaNcE
Aug 14, 2006 12:17 PM
HunterJoules
Jul 27, 2006 02:56 PM
