cable clutch...hydro tranny
Old Jun 10, 2006 | 02:23 PM
MniMeHatch89's Avatar
Default cable clutch...hydro tranny
i bought a 93 coupe and the clutch is bad and my friend has a cable clutch for sale. will it work right?
Old Jun 10, 2006 | 03:02 PM
b18sihatch's Avatar
Default Re: cable clutch...hydro tranny (MniMeHatch89)
if your car is cable and his clutch disc is for a hydro the splines are different and wont work you will have to get a clutch that will fit your application, but his clutch pressure plate will work
Old Jun 10, 2006 | 03:41 PM
so the splines on the clutches are different?
Old Jun 12, 2006 | 04:45 PM
Bense's Avatar
Default Re: cable clutch...hydro tranny (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">if your car is cable and his clutch disc is for a hydro the splines are different and wont work you will have to get a clutch that will fit your application, but his clutch pressure plate will work</TD></TR></TABLE>
not entirely true.
1988 have one spline less than all the other 89-00 clutches.
if it's a 1988 clutch disk, i belive it's 20 splines, then it won't work
if it's a 21 spline, i believe it will. Might try searching the EF forum.
clutch + pressure plate will work fine. (if it's 1989-1991)
CDizzle_996
Transmission & Drivetrain
Jan 26, 2013 12:32 PM
hammergunner
Aug 31, 2008 01:23 AM
DustinM
Mar 25, 2007 11:22 AM
SiBuddy00
Jun 21, 2005 07:57 PM
asmallsol
Aug 9, 2004 08:06 AM
