Limp mode and no code. Then nothing. WTF?
Old Jun 10, 2006 | 02:10 PM
User 5426's Avatar
Default Limp mode and no code. Then nothing. WTF?
While driving back from a 15 mile drive. The check engine light came on and the car went into limp mode (3k rev limit), and the rpm rose from 700 to 1200. I Immediately pull the car over and checked for codes. NOTHING. I turned the car off then back on and the light was gone. The car ran for about a minute completely normal. As soon as my bro jumped into the passenger side the same thing happened but this time, the car turned off. After the third time starting it, the car ran perfect and still no check code recorded.
As I am typing this I am starting to wonder if the ecu was being hit by my brother.
UPDATE: problem fixed. Click Here
Modified by EsQueue at 1:35 AM 6/26/2006
Old Jun 10, 2006 | 02:17 PM
98vtec's Avatar
moderator emeritus
Default Re: Limp mode and no code. Then nothing. WTF? (EsQueue)
could have blown the CEL bulb after what i'm guessing is something electrical.
Old Jun 10, 2006 | 02:23 PM
Beau Gotti's Avatar
does the CEL come on when you turn the key "on"?
if not then you probally have a blown bulbs
Old Jun 10, 2006 | 05:43 PM
User 5426's Avatar
Default Re: (Beau Gotti)
The bulb works, it comes on during starting.
Old Jun 10, 2006 | 06:16 PM
Beau Gotti's Avatar
do you have your ECU in the floor not mounted properly?
he could have been kicking it with his feet if you have a loose connector
Old Jun 10, 2006 | 06:29 PM
User 5426's Avatar
yeah, it's just laying there behind the carpet. I'll probably have to make some type of custom mount.
Old Jun 10, 2006 | 06:42 PM
Beau Gotti's Avatar
dose it not have a mounting plate like the 97+? i know the 3rd gens are that way too. its possible it was grounding out on the floor to.
Old Jun 10, 2006 | 06:58 PM
User 5426's Avatar
I have an h22 in an eh2. The person who did the swap probably did a rush job. I had to correct lots of things.
Old Jun 26, 2006 | 12:24 AM
User 5426's Avatar
Default Re: (EsQueue)
Update: On my way home, on the freeway and a few hours ago, the check engine light came on again. The engine sounded like when you gas a vehicle while moving and the key turned off. Moving the ecu didn't help it this time so I exited the freeway and pulled into the nearest parking lot. I could tell that it was running rich as hell by the smell of the exhaust.
I checked for a code with no success. I began to think that it must be the ecu going bad so I decided to unplug and disasemble it. Upon opening it I noticed that the "Main Chip" (the one that you can change) was almost completely unpluged. Poped it back in, reasembled the box, started the car and no more problem.
Old Jun 26, 2006 | 12:30 AM
98vtec's Avatar
moderator emeritus
ha, what ecu is it?
i've never heard of that problem on a virgin ecu. Only with people running zif sockets with their eprom chips or ostrich.
Old Jun 26, 2006 | 12:32 AM
User 5426's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">ha, what ecu is it?
i've never heard of that problem on a virgin ecu. Only with people running zif sockets with their eprom chips or ostrich.</TD></TR></TABLE>
P13
Yeah, not virgin cheap radioshack plug.
Dead CIVIC
Jul 28, 2009 07:17 PM
Siegfried
Jul 3, 2006 09:42 PM
wilsel
Apr 15, 2005 05:18 AM
CapnChunk
Mar 23, 2003 07:33 AM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
