B17 with P30's
Old Jun 10, 2006 | 01:31 PM
Death_to_Thieves's Avatar
Default B17 with P30's
I've checked the C speed calculator for the compression on this setup and results were 11.3:1 with 2 layer headgasket and 10.9:1 with 3 layer OEM gasket for .25 OS P30's in a B17. Just wondering if anyone could verify this for me. I've read in the past that this calculator is not accurate at times. I have also done alot of searching and was only able to find threads regarding CTR pistons in a B17, not P30's. If my compression is at about 11.3, should I ditch the BC3+ and go with some Blox B's? Thanks in advance for your help
Old Jun 10, 2006 | 06:41 PM
Default Re: B17 with P30's (8000KReV)
Calling all engine builders!
Old Jun 10, 2006 | 06:59 PM
95TegSE's Avatar
As far as I know, the calculator is only wrong with CTR (PCT) pistons, the rest are pretty correct.
Old Jun 11, 2006 | 12:14 AM
broketuner-Sol_Si's Avatar
Default Re: B17 with P30's (95TegSE)
if you do decide to ditch the buddy clubs and want to sell them I might be interested in them. But I've heard that the BCs are good for a wide range of CRs. The Blox Bs will give you more up top but not as much in the mid lke the BCs.
Old Jun 11, 2006 | 10:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE &raquo;</TD></TR><TR><TD CLASS="quote">As far as I know, the calculator is only wrong with CTR (PCT) pistons, the rest are pretty correct.</TD></TR></TABLE>
Good to know. So Im going to assume that 11.3 is correct. I'm still not decided on what cams to choose though. I think IM going to stick with the BC3+. I'd like to know how high they will make power. I know people that have had them fall off about 8k, but thats with their motor only being stock compression B16's (10.2) and GSR's (10.6). I wonder if my compression being just a little higher will cause them to make power a little further into the RPMs, like 8500 or something. What do you guys think?
Old Jun 13, 2006 | 12:54 PM
no thoughts on this?
dc2ls-vtec
Aug 8, 2008 06:35 AM
PinkMaggit
Dec 17, 2005 10:09 PM
WhoDoYouThink
Oct 4, 2005 01:02 AM
emotionisdead
Apr 6, 2004 07:59 PM
Twigster311
Apr 13, 2003 01:06 AM
