Finished MINIME but no compression???
Old Jun 10, 2006 | 01:24 PM
CO_CReX's Avatar
Default Finished MINIME but no compression???
Ok guys, I just finished throwing my Z6 head on my B7 bottom and plugged everything back in etc. And the car wont start for ****. I made sure my timing was perfect and everything. I did a compression test and came up with 0 across the board. Anyone know why the hell this is happening? Its not making any sense to me. Also can anyone show me how to make sure the head is correctly timed? Where is the mark on this? I just used a haynes manual and went off of what theres looked like. ANY HELP!?! Thanks!
Old Jun 10, 2006 | 01:54 PM
schardbody's Avatar
read the big mini-me write up by bauley civic at the top. the timing isnt dead on w/ the b7/z6 mini me, hope you didnt bend your valves.
Old Jun 10, 2006 | 04:17 PM
CO_CReX's Avatar
Default Re: (schardbody)
ttt
Old Jun 10, 2006 | 04:38 PM
order23's Avatar
Default Re: Finished MINIME but no compression??? (CO_CReX)
check the shredder valve on the tester ...it should flutter.......if it stays at zero then get another tester....
Old Jun 10, 2006 | 06:05 PM
Syndacate's Avatar
if the valves are stuck open b/c they're bent to **** it may not flutter...
Old Jun 10, 2006 | 06:53 PM
CO_CReX's Avatar
Default Re: (Syndacate)
we have tried now two different compression testers.. and both still read 0 compression..
different spark plugs, and spark plug wires.. the car cranks, but theres no ignite..
any ideas?
thanks
Old Jun 10, 2006 | 06:55 PM
CO_CReX's Avatar
Default Re: (CO_CReX)
also, we did a valve timing as well on it, and still same thing..
Old Jun 10, 2006 | 07:21 PM
djbutler007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">read the big mini-me write up by bauley civic at the top. the timing isnt dead on w/ the b7/z6 mini me, hope you didnt bend your valves.</TD></TR></TABLE>
Old Jun 10, 2006 | 07:23 PM
CO_CReX's Avatar
Default Re: (djbutler007)
thanks man.. but we've read it 5 times now.. and were talking bauley civic (creator of the fourm for the mini swap).... any other ideas??
Old Jun 10, 2006 | 10:54 PM
CO_CReX's Avatar
now we have a compression ratio of.... 90 across the board... but still it would start any suggestions?
Old Jun 10, 2006 | 10:59 PM
schardbody's Avatar
90 is still way low dude.
Old Jun 11, 2006 | 12:02 AM
nutball72's Avatar
are the wires in the right firing order. the haynes manual was wrong on the firing order, i had to switch two wires i think 3 and 4. also will the car start if you gas it all the way? if it does and runs like **** try unplugging some spark plug wires, the ones that done effect he engine switch. no idea if this is the prob but the exact same thing happened to me, give it a try and dont trust haynes firing order!
Old Jun 11, 2006 | 06:17 AM
CO_CReX's Avatar
Ok, well how much compression should I have with a motor with 133K? Also do you think the compression is so low because I didn't use a Z6 headgasket? I used a non vtec one and had to trim around farthest 2 bolt holes to make it fit... Also can you use a B7 distributor? or does it have to be a Z6 or Y8? If so how do I do this?
Old Jun 11, 2006 | 06:22 AM
nutball72's Avatar
WHY, didnt you use a z6 head gasket ts so cheap! and would have fit just right, if thats not your problem now it will be later...
Old Jun 11, 2006 | 06:25 AM
TorquelessB16's Avatar
uh oh. ur sposed to use the y8 HG.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutball72 &raquo;</TD></TR><TR><TD CLASS="quote">are the wires in the right firing order. the haynes manual was wrong on the firing order, i had to switch two wires i think 3 and 4. also will the car start if you gas it all the way? if it does and runs like **** try unplugging some spark plug wires, the ones that done effect he engine switch. no idea if this is the prob but the exact same thing happened to me, give it a try and dont trust haynes firing order!</TD></TR></TABLE>
How the hell does HAYNES mess something as simple as that up?
Old Jun 11, 2006 | 06:37 AM
tatmark1's Avatar
use the z6 head gasket.
must be doing sum thing wrong on comp. test went from nothing to 90 across.very low but consistant. how many times you cranking it
Old Jun 11, 2006 | 06:42 AM
nutball72's Avatar
Default Re: (ZeeSix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeeSix &raquo;</TD></TR><TR><TD CLASS="quote">uh oh. ur sposed to use the y8 HG.
How the hell does HAYNES mess something as simple as that up?</TD></TR></TABLE>
maybe im just a retard but i checked that manual 8 times, and they say its a simple clockwise roatation from 1 to 4 starting at th bottom but on my car they were mixed up, so either my car is wacked out (very pssible) or haynes sucks for firing orders
Old Jun 11, 2006 | 07:42 AM
Orangecivic251's Avatar
Default Re: (nutball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tatmark1 &raquo;</TD></TR><TR><TD CLASS="quote">use the z6 head gasket.
must be doing sum thing wrong on comp. test went from nothing to 90 across.very low but consistant. how many times you cranking it</TD></TR></TABLE> what he said how many times you cranking it?
Old Jun 11, 2006 | 04:18 PM
CO_CReX's Avatar
Im cranking it for about 10 seconds or a little more. It bumps up to 90 and just chills there... Also only reason I used a non vtec head gasket is because one of my friends had a new one just layin around and I called everywhere in my city including honda and every place had to order one... So it looks like tomarrow Im going to call and order one. Also the reason my compression went from 0 to 90 was because my valves were staying open. Anyone know the spec for this? Like what feeler gauge I should be using to make sure these are closed correctly? They could be slightly open and thats why I only have 90... Thanks for the help though guys, I really appreciate it.
Old Jun 11, 2006 | 04:57 PM
CO_CReX's Avatar
OK guys, I just went out and redid another compression test with a wideopen throttle, and my numbers changed. Its like from cyl 1 to 4 the compression gets better.
1 = 40
2 = 50
3 = 70
4 = 110
Any ideas what this could be? Im REALLY leaning towards the headgasket now...
Also does anyone have an answer for me about the B7 distrubitor on the Z6 head?
Old Jun 11, 2006 | 05:22 PM
tatmark1's Avatar
you need a z6 head gasket and Z6 dizzy
Old Jun 11, 2006 | 07:15 PM
mathieucivic's Avatar
you need the Z6 dizzi because the bolt location and timing is different.
check your valves ajustement, 0.088 for the intake and .010 for the ex.
and the timing belt install differently on Z6 (not the 2 horizontal mark but the one on the lower left of the cam pulley)
have good luck
Old Jun 12, 2006 | 03:57 PM
CO_CReX's Avatar
Default Re: (mathieucivic)
Ok guys, I went out today and tracked down a Z6 head gasket. It is a metal 3 layer gasket. Great quailty comparred to the ceramic POS one that I used on the motor before. So Im pretty sure this is going to help out the compression a good deal. I'll be back with updates and a new compression test with the ECU fuse unplugged...
Im still looking for a Z6 distrubitor locally.
Old Jun 12, 2006 | 08:22 PM
CO_CReX's Avatar
OK, so I cleaned everything up REAL nice and put the new headgasket on and torqued it down tonight... I still have to plug everything up and set my timing. Can anyone tell me where to point the the TDC mark on the camshaft to set the timing on the cam? I have heard many places that you match it up to the mark on the back of the cover... but I have searched that cover up and down and can't find a freakin mark. Any help? possibly pics?? New update tomarrow!
Old Jun 12, 2006 | 11:39 PM
Br1anPham's Avatar
Don't know why anyone would mention the distributor, it has nothing to do with your compression. I'll put my money on bent valves. You should have check the valves when you took the head off when changing your head gasket.
