foglight install 92 eg hatch
engine bay harness i got
1. positve hooked up directly to my battery
2. then the harnes goes off to a relay then to both lights plug in's
3.a red wire that goes into the inside of the are.
inside harness
1. i got the switch and it's pluged in then it goes to a ground
2. one goes to the fues box i don't know where at??
3. the last one hooks up to the engien bay harness wire.
This was a ebay kit that never came with instuctions.
i've been searching
i just hope i got everything hooked up right so far.
i looked at honda oem install but it's nothing like mine.
let me know if anyone's has help.
Thanks again.
inside harness
i've been searching
Thanks again.
Sounds like you got most of the wiring done. For the fuse box plugs, the red/black wire goes to #2 in the accessory slots and the large white wire goes to #5. The accessory slots are labeled. The wiring is for OEM fogs, which should be similar to the Depo ones. Make sure you ground the outside harness.
see i got 2 2-5's the one for fuses and one for plugs??
and all i got on the inside harness is
1 plug for the switch
1 ground
1 wire to connect to the engine harness
1 wire to the fuse box
i can take pic i you like cause i really would like to get this done. lol
Thanks for the help so far.
1 ground
Fuse box still unsure ware to put the yellow wire in the pic below
yellow wire seems to be the fuse box wire and there is the ground wire behind it.
http://www.flickr.com/photos/61679240@N00/164974554/
switch
http://www.flickr.com/photos/61679240@N00/164974552/
ground going up to the engine ground and both fog light plug in's
http://www.flickr.com/photos/61679240@N00/164974549/
relay and inline fuse
http://www.flickr.com/photos/61679240@N00/164974546/
positive connected to the battery
http://www.flickr.com/photos/61679240@N00/164970043/
switch
the second fuse or the second plug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyles ej1 »</TD></TR><TR><TD CLASS="quote">it goes in the 2nd one</TD></TR></TABLE>
here is my writeup on the Depo fogs.. might help you out
https://honda-tech.com/zerothread?id=1352749
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">relay is a common thing to just go bad. you can pick one up at the part store for about 2-3 bux</TD></TR></TABLE>
I tried everything on mine (replaced the relay, tried multiple switches, followed your write-up which is very helpful) and it wouldn't work. Come to find out my harness was wired incorrectly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">
Not hard to run the wires the right way man...
If you look at the bottom of the relay you will see some numbers.
Numbers should be right by the Pins.
Pin30- This goes to the battery ( Has a ring terminal on it.
Pin87- This should go to the foglights them selves.
Pin 85- Should be Black and have a ring terminal.. This goes to a Chassis Ground
Pin86- This goes to your fuse box to turn on the Relay and send the power to the foglights.
</TD></TR></TABLE>Not hard to run the wires the right way man...
Pin86- This goes to your fuse box to turn on the Relay and send the power to the foglights.</TD></TR></TABLE>
Wish I would've know that when I had my harness. I sent it back to JDMSh!t, they're going to mail me a new one.
yeah i know it's only a couple of wire i even tried to by pass the power going through the relay blew a fuse and connected and wire in there just to see if the light would come on with a toggle and nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 CIVIC HATCH VX »</TD></TR><TR><TD CLASS="quote">yeah i know it's only a couple of wire i even tried to by pass the power going through the relay blew a fuse and connected and wire in there just to see if the light would come on with a toggle and nothing.</TD></TR></TABLE>
did you try to wire it the way i just told you to? if you do not have the bulb seated correctly in the foglight it will connect with the ground and short and blow the fuse.
