valve/piston clearence question
Old Jun 10, 2006 | 08:45 AM
remoer's Avatar
From: fountain inn, sc. where they still rock banjos on porches, usa
Default valve/piston clearence question
i was told that i would a clearance problem with the setup i'm building and people cut the valve reliefs. if so, please enlighten me with some info or anyway. even how to. thanks.
d15b7 head pnp
d16z6 im - portmatch to the tb
95 gsr tb 60mm
272 Delta re-grind cam
eldbrock ajustable cam gear
d16y8 2 layer gasket
d16a6 block
p29 piston
this should yeild 11:44.1 compression. i'll be tuning w/93 octane
now this will be going into a 90 crx which i will be converting it from ODB0 to ODB1 to run crome pro cause i'll also be running cbr600rr itb.
please any info would be helpful due to i already have 3/4 of the part and should be done by late aug-early spet. thanks.
Old Jun 11, 2006 | 01:57 AM
remoer's Avatar
Default Re: valve/piston clearence question (remoer)
no help yet?
#Leo#
May 10, 2010 12:26 PM
GSR4U2NV
14
May 25, 2005 04:16 PM
Steve91
Dec 17, 2004 03:47 AM
jetpilot
Apr 25, 2004 10:05 AM
