Rod/Stroke question
Old Apr 15, 2002 | 07:56 PM
XoSiKCiViCoX's Avatar
Default Rod/Stroke question
Does anyone know the formula to calculating Rod/Stroke Ratio's????
Old Apr 16, 2002 | 12:38 AM
carsaregood's Avatar
Default Re: Rod/Stroke question (XoSiKCiViCoX)
you take your rod length, and divide it by your stroke length, so its a dimensionless ratio.
For example, lets say your rod length is 6.625 in, and your stroke is 3.750 in. Your r/s ratio is then 1.766:1.
I've seen different ideal r/s ratios... some say 1.75:1, some say 1.6:1... i dunno which is better. But from what i've read, shorter rods result in higher piston speeds, which means the engine can pump more air. There's a lot of engine theory that goes into this...but right now i'm too lazy to really read up on it and summarize here... i'm getting this info from a high performance pontiac magazine.. my roommate has a GTO. I can read it later and explain it better later if you'd like.
10K2HVN
Mar 17, 2003 11:16 AM
boosted3g
Jan 9, 2003 02:28 PM
Mover
Oct 28, 2002 05:22 AM
Spade
Nov 8, 2001 08:15 PM
