is there a difference between a gsr head gasket and a SI head gasket?
Old Jun 9, 2006 | 08:16 PM
tatted91rex's Avatar
Default is there a difference between a gsr head gasket and a SI head gasket?
right as the question asks~
Old Jun 9, 2006 | 09:43 PM
Default Re: is there a difference between a gsr head gasket and a SI head gasket? (tatted91rex)
anyone? i need to know
Old Jun 9, 2006 | 10:00 PM
crxnj's Avatar
all the dohc vtec b-motors have the same head gasket
Old Jun 9, 2006 | 10:23 PM
SD_Lurker's Avatar
HT White Ops
There are several Si models. It would be very helpful if you could be a little more specific!
Old Jun 9, 2006 | 10:52 PM
Default Re: is there a difference between a gsr head gasket and a SI head gasket? (nicks_jdmstyle_ef9)
its a first gen b16 but i was wondering about the head gaskets because i just had a valve job done to my head and the cars not running right its not getting oil to the head soo either somethings clogged or blocked soo i thought maybe i got the wrong head gasket
Old Jun 9, 2006 | 11:58 PM
philkehn's Avatar
sir, .. b series should all have the same head gasket fitting im pretty positive
Old Jun 10, 2006 | 12:43 AM
Twilight's Avatar
Default Re: (philkehn)
You should always replace headgasket after taking the head off.
Every shop should know that. Unless you did it by yourself.
Old Jun 10, 2006 | 12:04 PM
Default Re: (Twilight)
nah i did it myself at my brothers shop i did replace the head gasket just the set i got was for b16 it said b17 and b18c soo didnt know if there was a difference what else could it possibily be ? why wouldnt i be getting oil tot he head if nothings blocked maybe my oil pump went bad from sitting with no head on it for about two months?
tuck1crx
Oct 12, 2010 02:59 AM
fireman mike2288
Mar 13, 2008 10:35 AM
filetofit
Aug 13, 2002 08:49 PM
