radiator support removal? (searched)
Old Jun 9, 2006 | 07:33 PM
JCracer723's Avatar
Default radiator support removal? (searched)
anyone knows where i can find a how-to remove the radiator support (spot weleded)
how hard is it?
ive serached but every post that i found with the title wasnt answered.. thanks
Old Jun 9, 2006 | 07:48 PM
downest's Avatar
Default Re: radiator support removal? (JCracer723)
Shouldn't be spot welded... are you sure you have all the bolts out? If there are spot welds just chisel or drill them out.
Old Jun 9, 2006 | 07:58 PM
JCracer723's Avatar
Default Re: radiator support removal? (downest)
well im not sure ... the reason im asking uts because there is a HB for sale with rad support damage.. just wondering how hard is it before i make up my mind.
Old Jun 9, 2006 | 08:21 PM
downest's Avatar
Do you have an EF now? Look at the support, I think it's 5 bolts and the hood cable... not definite though. I know it's not welded, I've had my whole front end apart with a 10mm socket.
Old Jun 9, 2006 | 09:29 PM
JCracer723's Avatar
hmm intersting.. i was told it was spot welded..
just to make sure we are talking about the same thing.. is it the whole thing side to side (fender to fender) where the head lights bolt on to? bottom part where the radiator sits?
Old Jun 9, 2006 | 11:52 PM
philkehn's Avatar
yea there should be 4 to 6 bolts underneath there no welded and the two black hangers that are on the headline support
Old Jun 10, 2006 | 01:48 AM
88 rex's Avatar
Default Re: (philkehn)
It depends on what we are actually talking about here. The lower mounts for the stock radiator are spot welded to the car. I drilled the spot welds and went to town with an air hammer. You need to remove them when you install the full-race bars.
Old Jun 10, 2006 | 05:36 AM
downest's Avatar
Default Re: (88 rex)
Ok I thought you were talking about the T-Bar piece at the top. That bolts on. The lower crossmember will unbolt too, but yes, the brackets for the radiator are spot welded.
Old Jun 10, 2006 | 07:27 PM
powerpro_69's Avatar
Default Re: (downest)
its not that hard just have a frame shop do it cuz they will have to pull the frame
boostedef123
Mar 21, 2012 04:04 PM
kraven9
13
Sep 14, 2006 03:41 AM
beyondspexj
Dec 18, 2005 08:28 AM
rhetorical
Jun 21, 2004 09:10 PM
EF_LSVtec
14
Jun 28, 2002 09:13 PM
