barometric pressure sensor code
Old Apr 15, 2002 | 07:07 PM
Cm91h22a's Avatar
Default barometric pressure sensor code
baro pressure sensor keeps going off i've tried 3 different ecu's and it keeps going off in my 91 integra which is completely stock
Old Apr 15, 2002 | 07:33 PM
rainforest's Avatar
Default Re: barometric pressure sensor code (Cm91h22a)
try a new throttle body/map sensor. and you will be good.
Old Apr 15, 2002 | 08:01 PM
Cm91h22a's Avatar
Default Re: barometric pressure sensor code (rainforest)
Thanks man I"ll give it a shot
Old Apr 16, 2002 | 12:38 AM
dustin's Avatar
Nah the barometrics pressure sensor isn't in the throttle body. It depends on which ecu you are using. OBD1 cars had the sensor INSIDE the ecu. Older cars had an external sensor under the dash. I'd check the service manual for your car to verify the location of the sensor.
All the sensor is is a map sensor that reads open atmosphere all the time (to get the TRUE map reading by comparing it to manifold vacuum).
Dustin
sh!ft
May 13, 2009 01:18 PM
ef9_civic_hatch
May 13, 2007 03:50 PM
-JSpecEk*9-
22
Jun 8, 2006 02:26 PM
sharky8513
12
Feb 5, 2005 08:25 AM
Civic89
Jun 17, 2002 01:26 PM
