engine wont start under hot sun
Old Jun 9, 2006 | 01:18 PM
FlyingDaggers's Avatar
Default engine wont start under hot sun
I have a 94 lude 5spd h23....everytime that car sits under the sun for too long....i can't start it. It'll just crank n crank n crank. When the days cool down, like when sun starts setting n temp dropping, then i can start it. Can someone please help me figure out why its like that...some say its the main relay. Help asap thanks
daggers
Old Jun 9, 2006 | 01:21 PM
AfricanBush's Avatar
Default Re: engine wont start under hot sun (FlyingDaggers)
main relay. u can take it apart and re solder it and it should work alot better. i had the same problem and thats how i fixed it.
Old Jun 9, 2006 | 01:26 PM
Default Re: engine wont start under hot sun (AfricanBush)
thanks bro--------
Old Jun 9, 2006 | 03:00 PM
ninja 6's Avatar
Default Re: engine wont start under hot sun (nyluder)
at the dealer it costs like 84 dollars
Old Jun 9, 2006 | 03:20 PM
kulrevon's Avatar
Default Re: engine wont start under hot sun (fish stick)
to check if it is the main relay is simple. When you are having a problem starting it turn the ignition to the on position the check engine light should go on for 2 secs then turn off. If it doesn't go off it is almost definatly the main relay. it it doesnt go off you can try hitting or kicking the dash down by your left leg and the light should go off. and after the light goes back off the engine should start fine.
Yuta
Jun 8, 2016 08:44 PM
samquebe
Dec 10, 2012 08:04 PM
nismogrendel
Apr 24, 2010 01:43 AM
Slow as piss
Oct 4, 2005 02:10 PM
Chief Brody
Aug 30, 2005 08:58 AM
