Installing my stock shifter, need torque specs!!
Old Jun 9, 2006 | 12:56 PM
RGoose18's Avatar
Default Installing my stock shifter, need torque specs!!
After deciding my stock shifter suits me more so than the DC short shifter w/ poly bushing I'm taking the whole setup out. Does anyone know the torque specs on the bolt that goes through the circular rubber bushing right up against the tranny. It's a 12 mm bolt. Thanks
Old Jun 9, 2006 | 03:12 PM
BJOnewiper's Avatar
Torque spec: tight
Old Jun 9, 2006 | 03:21 PM
RGoose18's Avatar
Default Re: (notoriousEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Torque spec: tight</TD></TR></TABLE>
I tightened it all the way and it seems to veer off to the left and the other end of the bar isn't lined up properly. Anyone else have this problem?
Old Jun 9, 2006 | 05:19 PM
92TypeR's Avatar
FSAE
Default Re: (RGoose18)
Are you sure you have everything put back together correctly? The bolt shouldn't cause any problems, its either on or off.
Old Jun 9, 2006 | 05:31 PM
BJOnewiper's Avatar
DOn't have a type r car per say, but did you remember to add the mental plate over the rubber/poly pad that snugs everything to the underside of the car?
ray.riddler92
Jul 27, 2011 05:07 PM
sickofitall1113
Oct 7, 2007 05:28 PM
Extreez
Apr 13, 2007 01:08 PM
Bob#455
Mar 27, 2002 09:30 PM
