dying car
i just got done with my search and nothing to help i was just wondering if any1 eles is having the same problem and what you did to fix it.
my battery light keeps coming on and then my lights dont work i had the battery and alt changed and i still have the same problem but now the car keeps dying i have checked the alt and battery and they are fine plz help
It could be wiring in general.
Check the wire attached to the alternator where the nut is , then check the harness to make sure it's tight in the alternator. Check all your grounds and make sure you've got good Batt. terminal.
Are you sure the alternator is new ? How did you remove the alternator if so ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock4now »</TD></TR><TR><TD CLASS="quote">a bad ground on what the bat or the alt
there are grounds all over the car. check all of them.
Ok , but alot of ppl claim they "changed" there alt. and you ask how and they say simple , took old out and now in. And most of us know theres alot more to it than that. If you drverside axle didnt come out , then neither did your orig. alt.
I still guess you should look at the wiring more . You have to be overlooking it somewhere.
i would say check grounds. there one that goes from the teminal to the body right on top of the head light. and the one that goes from the valve cover to the body right above the headlight i had the same problem but thats because i did hook the valve cover one back up. i did say those 2 would be ur best guess. before u start looking all over the motor.
BIG_WILL
Nov 16, 2008 07:06 PM
mkhooaah
Jul 28, 2003 08:15 AM
