how 2 drain a 1989 ef gastank?
get under the car on the drivers side of the fuel tank ,,its right by the lower control arm and is a 17mm bolt if i remember...just be carefull with that gas,,dont smoke
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nautica_t »</TD></TR><TR><TD CLASS="quote">if you're lucky enough to have a bolt there.
i didn't have a bolt there so had to cpyhen it out as much as i can and than i dropped the tank and cpyhen it again. </TD></TR></TABLE>
that means your gas tank was replaced with aftermarket...the oem tanks have it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">you dont have to drop the gas tank to change the fuel pump...just take out the backseat</TD></TR></TABLE>
its not like that with our cars...we dont have 94+ integras and 92+ civics,,on our cars you have to drop the gas tank
easy with the fuel lines, when i took out my tank i was taking off my main fuel line and it was the bolt was rusted to the fuel line and i ended up ripping hte fuel line and its very time consuming to change the fuel line. i would recommend spraying it with some wd40.
heretolearnandteach
Oct 22, 2006 12:58 PM
