Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2003 Pilot shakes.
Old Jun 9, 2006 | 05:29 AM
cmonroe5's Avatar
Default 2003 Pilot shakes.
Tech question for my 2003 Honda Pilot EX 50K.
.At exactly 25mph while driving on a smooth road with few bumps, I will go over a small bump and the entire car goes into a crazy Harmonic Shake that lasts for up to 10 seconds.
The car has been checked out several times and nothing was found. What may be causing this to happen only at this speed??
Old Jun 9, 2006 | 05:57 AM
Ross 2.0's Avatar
In a Junkyard near you.
check your tire pressure
Old Jun 9, 2006 | 06:02 AM
cmonroe5's Avatar
Default Re: (MooGoCow3)
Thanks..but it is much more then that. Perhaps a loose suspension part
Old Jun 9, 2006 | 08:24 AM
Ross 2.0's Avatar
possibly. I would say a sway bar or something like that then. But if it was put up on a lift they should have been able to find that
Old Jun 9, 2006 | 08:31 AM
GreenD's Avatar
Default Re: (cmonroe5)
it sounds like your EGR valve. its a common problem in 03's and some 04's. there was also a TSB on it.
http://www.hondapilot.org/foru...11622
http://www.hondapilot.org/foru...=6510
http://www.hondapilot.org/foru...=8943
http://hondapilot.org/forums/s...13808
Old Jun 9, 2006 | 09:37 AM
Ross 2.0's Avatar
Default Re: (GreenDestiny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenDestiny &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like your EGR valve. its a common problem in 03's and some 04's. there was also a TSB on it.
Not quite. An egr will create more of a "bucking" or "surging" feel.
Old Jun 9, 2006 | 09:44 AM
cmonroe5's Avatar
This is a speed specific issue not related to EGR, which was replased. A simple small bump in the road makes the car shake big time only at 25mph. Very predictable on only 3 roads in my area.
Old Jun 9, 2006 | 11:01 AM
Ross 2.0's Avatar
you may have a bad shock or strut.
How does it take corners?
Old Jun 9, 2006 | 07:02 PM
cmonroe5's Avatar
It takes corners like a pilot crappy OEM tires suck.
Old Jun 10, 2006 | 05:37 AM
Ross 2.0's Avatar
well i've suggested all i can think of right now...
Old Jun 12, 2006 | 01:46 AM
graveltravel2's Avatar
get a wheel balance done.
Old Jun 12, 2006 | 10:37 AM
fishwgoose's Avatar
Default Re: (graveltravel2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel2 &raquo;</TD></TR><TR><TD CLASS="quote">get a wheel balance done.
also have they checked the drive train? it could be loose and when it's shifting gears the bumps causes it to shake...just a thought
Old Jun 12, 2006 | 03:14 PM
trust me man.. my wife drives a 03 pilot..
go get a tire roatation+wheel balance.
it will solve the problem.
Old Jun 12, 2006 | 04:11 PM
cmonroe5's Avatar
Thanks..balanced rotated, aligned still shakes.
Old Jun 12, 2006 | 11:10 PM
hummss....
well.... something isnt right ......
that should have fixed it.
it must be something wrong with the suspension then.
check out
look for the problems section.
Old Aug 11, 2006 | 09:21 PM
Qfactor's Avatar
Default Re: 2003 Pilot shakes. (cmonroe5)
have you had a transmission replaced lately, check the front subframe could be loose bolts.
emwavey
Sep 17, 2003 10:07 AM
88crx Osaka
Apr 7, 2003 09:47 PM
Lord Helmet
Feb 22, 2003 09:58 PM
