rear disk brakes?
its for hte rear, not front.
all you need is a pair of needle nose pliers, you have to 'screw' the piston back into the caliper.
There is a special tool for some rear disc too. http://www.sears.com/sr/javasr...e=Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">There is a special tool for some rear disc too. http://www.sears.com/sr/javasr...e=Yes</TD></TR></TABLE>
$12 not bad... usually a tool at sears is.... $50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlee ricer »</TD></TR><TR><TD CLASS="quote">get a big enough c clamp and put the sucker in.just squeeze the whole caliper.</TD></TR></TABLE>
do NOT listen to this guy. he's either never worked on rear discs before or has bad reading comprehension.
you just need to turn the piston back in. dont push. i just use the edge of a small file to turn the piston between the slots. the special "tool" i assume is convenient, but not really worth buying in my opinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">
you just need to turn the piston back in. dont push. i just use the edge of a small file to turn the piston between the slots. the special "tool" i assume is convenient, but not really worth buying in my opinion. </TD></TR></TABLE>
agreed, this is what i did. there is a special tool for the front
for the FRONT i use a carpenters "quick-grip" squeezable type vice, or channel lock pliers.
ive found the special "tool" for the front caliper useless as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">for the FRONT i use a carpenters "quick-grip" squeezable type vice, or channel lock pliers.
ive found the special "tool" for the front caliper useless as well.</TD></TR></TABLE>
i have found the tool for the front helpful, c clamps work just as good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">too much turning of the screw. waste of effort.
channel lock pliers, one squeeze youre done.</TD></TR></TABLE>
i like wasting effort
yeah i usually just use chanel locks to push in the pistons for the fronts, but when i tried it on the rear they would not push in. i have never had rear disk brakes before. so what you are saying is the piston twists back into place and i cant just push it back in like the fronts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classciv »</TD></TR><TR><TD CLASS="quote">yeah i usually just use chanel locks to push in the pistons for the fronts, but when i tried it on the rear they would not push in. i have never had rear disk brakes before. so what you are saying is the piston twists back into place and i cant just push it back in like the fronts?</TD></TR></TABLE>
yes you NEED to twist them, they do not press.
its different than the fronts because of the parking brake mechanism uses a screw to mechanically push the piston out, rather than hydraulically.
if you really tried to push it in, youll destroy the parking brake screw.
Do you not read well? Not trying to be a dick head, but seriously. Good luck dude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">Do you not read well? Not trying to be a dick head, but seriously. Good luck dude.</TD></TR></TABLE>
dont post on my threds if you dont have anything helpful to say, not everyone here knows what they are talking about so i like to make sure i know exactly what i am doing before i put my life or anyone elses on the line.
thanks to anyone who is helping out
JapJunkie
Jul 22, 2004 11:15 AM
