90 si harness into a 90 dx?
NEVER i mean NEVER should you swap a harness in your car that differs from the oem, like you NEVER swap a 88 Si harness into a 90 HF, only the same model/year.
swapping a diff model / year will cause MAJOR headaches, unless you swap ALL of the wiring in the car. (front to back) w/ relays and everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 »</TD></TR><TR><TD CLASS="quote">2006 noobs rule
Except he's an 05er with ~650posts.
Anyways, he obviously wants to convert to MPFI. But you should never swap a harness, convertion is always best.
</TD></TR></TABLE>Except he's an 05er with ~650posts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">
Anyways, he obviously wants to convert to MPFI. But you should never swap a harness, convertion is always best.</TD></TR></TABLE>
I ment the 06 are smarter. yes its much more harder to swap in the si harness..
conversion harness better idea. run two injectors, change dizzy wiring or whatever..I did it long time ago wasn't to hard..
Wire up injectors, dizzy and run resistor box. Parts cost maybe 10$ at a scrap yard (I pocket them, definatly steal a dizzy, junkyards charge to much for a 15 year old dizzy that may or may not work) and about 20$ of wiring from PartSource, and about 2 hours of spare time with a guide, and voila, MPFI to the rescue.
mpfi conversions are so easy, i do that conversion in my sleep.
its only adding 4 wires runs from the enigne to the ecu and switching a few wires around at the ecu and lengthing a few wires. easy stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">[
/thread.</TD></TR></TABLE>
lol your favourite saying huh. i bet 50% of all your posts end with that..
now /thread! muhaha!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">
now /thread! muhaha! </TD></TR></TABLE>
well there is good reason for it. for one a search could have prevented this thread, for two, he can get his MPFI harness from them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM tuning702 »</TD></TR><TR><TD CLASS="quote">uhh..sorry to say but i swapped an 89 Si harness into my 89 DX with the stock Si motor and it worked fine..</TD></TR></TABLE>
or so you think.
or so you think.
You suck at life if you do that.
And FYI, I notice that temp always says:
Pic of said ... or ban.
Pic of said ... or ban.</TD></TR></TABLE>
quoted for my greatness
I didnt think so but I have a dx to mpfi harness but it looks ugly and I have a real clean si harness so I thought that I would ask first before I mess up anything. I wil just stick to my dx to mpfi harness and clean it up a little bit thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ak_ef9 »</TD></TR><TR><TD CLASS="quote">I didnt think so but I have a dx to mpfi harness but it looks ugly and I have a real clean si harness so I thought that I would ask first before I mess up anything. I wil just stick to my dx to mpfi harness and clean it up a little bit thanks</TD></TR></TABLE>
You could also send it to hasport and they could reloom it for you. Expensive, but they could.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr »</TD></TR><TR><TD CLASS="quote">You could also send it to hasport and they could reloom it for you. Expensive, but they could.</TD></TR></TABLE>
LOL, Dood, I can make that dx harness look better than the si one and it will be modded to whatever setup you need
Just call us, or email
Ryan
Just call us, or emailRyan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">
Ryan</TD></TR></TABLE>
RYWIRE FTW!
Just call us, or emailRyan</TD></TR></TABLE>
RYWIRE FTW!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">LOL, Dood, I can make that dx harness look better than the si one and it will be modded to whatever setup you need
I know. I bought my VTEC sunharness from you. Anyhow, I was just saying he could, RYWIRE skipped my mind.
uptownx24x
10
Jun 20, 2011 07:17 AM
crx-si
Sep 1, 2008 05:54 PM
