88 crx with soch vtec wont start no fuel help pls
hey was up i have a 88 crx with a soch vtec motor.everything is converted to obd1.there is spark but no fueal my pump doesnt kick in at all.check fuses still wont start.Could it be becouse im using a p72 now the p72 worked in my friends coupe in his single cam vtec let me know need help aasp i will try p28 tomorow for now just seeing if somebody might know wat it could be tnxs once again
you can try checking the big relay (forgot what it was called) which is located under your dash on the driver side... and all your grounds, especially the ground on your thermostat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sicivic »</TD></TR><TR><TD CLASS="quote">its called the main relay its directly upwards from you hood release its a bitch to undo but you'll get it</TD></TR></TABLE>
druidesque
Mar 31, 2011 11:23 AM
AgentJam
Aug 15, 2004 03:07 PM
