TILTON Twin Disc clutch kits
<U>Twin Disc Cerametallic Kits: </U> Includes Clutch Discs, Plate, Flywheel and bolts
- Rated Torque Capacity: All Motor (360lbs/ft) or Turbo(740lbs/ft)
B16A/B18
H22
K20/K24
S2000
PM for Price
<U>Carbon/Carbon Clutch Assembly Kits: </U>Includes: Clutch Discs, Plate, Flywheel, bolts and Hydraulic Release Bearing Kit
- Rated Torque Capacity: All Motor (360lbs/ft) or Turbo(860lbs/ft)
B16A/B18
H22
K20/K24
S2000
PM for price
<U>Single Disc Clutch Assembly Kits: </U>Includes Clutch Discs, Plate, Flywheel, and bolts.
- Rated Torque Capacity: “Light Spring” 250-275lbs/ft “Heavy Spring” 375-400 lbs/ft
- Cerametallic or Organic Disc
B16A/B18 (92-01 only) PM for Price
<U>Hydraulic Release Bearing Assemblies</U> $395.00
Available for the B/K series kits.
This system eliminates the stock slave cylinder, fork and release bearing.
Includes:
Hydraulic Release Bearing Assembly with steel braided lines and fittings.
Tilton 75-series Universal Master Cylinder Kit
Master Cylinder mounting adapter plate
Provides immediate response for quicker shifting
Improved modulation characteristics and pedal feel.
No need for continued adjustment of clutch. Consistent Clutch release.
Eliminate flex within stock slave cylinder/fork release mechanism for reliable clutch release
And a positive pedal feel
Eliminates heat related slave cylinder failures
Modified by exospeedAMcrx at 11:50 AM 6/14/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp »</TD></TR><TR><TD CLASS="quote">Just ordered mine today
thanks!
</TD></TR></TABLE>thanks!
Crab-Cakes
Jan 26, 2008 08:42 AM
ExospeedAMcrx
Nov 11, 2007 08:25 PM
blkonblkcrime
May 29, 2007 10:05 PM
redrex91
Jul 18, 2003 03:09 PM
