rear brake lines from drum setup to DISC...interchangeable????
Old Jun 8, 2006 | 08:37 PM
b16_madman's Avatar
Default rear brake lines from drum setup to DISC...interchangeable????
Basically I need to know ASAP!
88 civic hatchback stainless steel brake lines
are they compatible with a Complete rear disc setup from a DA integra?????
need to know tonight
Old Jun 8, 2006 | 08:53 PM
whiteguyndahood's Avatar
i dont believe they will work!
When you buy the kit from password it says comes with every thing but lines so im assuming you need different lines.
Old Jun 8, 2006 | 08:57 PM
jpciii's Avatar
your 88's would be for drum brakes (all hatchbacks came with drum brakes, right?)... you need ones for disk.
http://fastbrakes.com/shop/ind...db280
Old Jun 8, 2006 | 09:01 PM
Default Re: (jpciii)
[QUOTE=jpciii]your 88's would be for drum brakes (all hatchbacks came with drum brakes, right?)... you need ones for disk.
QUOTE]
except si's
I was searching around and looks like you will need the lines.
Old Jun 8, 2006 | 09:41 PM
b16_madman's Avatar
Default Re: (EF JUNKIE)
Thanks fellas.
The buyer of the old hatch is bringing a RTA drum setup to bolt right up ...phew.
Last minute pre-flight checkin baggage
Old Jun 8, 2006 | 09:44 PM
Stunna MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF JUNKIE &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=jpciii]your 88's would be for drum brakes (all hatchbacks came with drum brakes, right?)... you need ones for disk.
QUOTE]
except si's</TD></TR></TABLE>
No alll civic's from 88-91 came with rear drum.
Except the 1991 CR-X Si
Old Jun 8, 2006 | 10:02 PM
EL Vap133's Avatar
Default Re: (Stunna AARON)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stunna AARON &raquo;</TD></TR><TR><TD CLASS="quote">
Except the 1991 CR-X Si</TD></TR></TABLE>
Wow, nobody knows?
Only the 90-91 CRX Si came with rear disc brakes. No hatchback or Sedan came with them stock from the factory in the US.
Old Jun 9, 2006 | 02:49 AM
rexman's Avatar
Default Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
Wow, nobody knows?
Only the 90-91 CRX Si came with rear disc brakes. No hatchback or Sedan came with them stock from the factory in the US. </TD></TR></TABLE>
X2
Old Jun 9, 2006 | 05:13 AM
crx_88_si's Avatar
lol people spittin wrong info, el vap got it right, finally, lol.
to answer your question, you need Drum lines for drums and disc lines for discs, they are different.
Old Jun 9, 2006 | 05:15 AM
Got_soy's Avatar
Default Re: (crx_88_si)
stupid 05s spitting out wrong info
Old Jun 9, 2006 | 05:41 AM
temp's Avatar
answer = no. (unless you are using CRX Si lines)
SS lines FTW.
i know, i know...im late.
Old Jun 9, 2006 | 06:06 AM
b16_madman's Avatar
Default Re: (temp)
Thanks for the confusing as hell replies, gosh, even "which cars came with disc brakes" became a debate. I could care less!
This was b/c the hatchback's rear spindle got crossthreaded really bad late last night & the buyer was flying down this morning to but my hatch.
So he found a whole RTA assembly to swap out to get him home!
Old Jun 9, 2006 | 06:08 AM
temp's Avatar
Default Re: (b16_madman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16_madman &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the confusing as hell replies, gosh, even "which cars came with disc brakes" became a debate. I could care less!
So he found a whole RTA assembly to swap out to get him home!</TD></TR></TABLE>
yay?
Old Jun 9, 2006 | 06:12 AM
crx_88_si's Avatar
Default Re: (temp)
[QUOTE=temp]answer = no. (unless you are using CRX Si lines)
QUOTE]
might want to make that more clear.
88-89 CRX Si's had rear drums too.
ok... i think i got this right.
you have an 88 Civic Hatch back. you currently have the stock drum brakes w/ SS Lines. You want to put 90-93 integra rear disks on. You will need to get SS lines for a 90-91 CRX Si or any 90-93 integra.
Old Jun 9, 2006 | 06:13 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=temp]answer = no. (unless you are using CRX Si lines)
QUOTE]
didnt need to as EL VAP already clarified
Old Jun 9, 2006 | 06:32 AM
crx_88_si's Avatar
i was referring to the original posters possible situation as he wasnt 100% clear.
smart ****!
Old Jun 9, 2006 | 06:35 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">i was referring to the original posters possible situation as he wasnt 100% clear.
smart ****! </TD></TR></TABLE>
why thank you
Old Jun 9, 2006 | 07:50 AM
JapJunkie's Avatar
Default Re: (temp)
No, drum lines and disc lines are not interchangeable. When looking at them, there is an obvious difference. Check it out and let us know..Im like 99% sure.
Old Jun 9, 2006 | 07:52 AM
temp's Avatar
Default Re: (JapJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie &raquo;</TD></TR><TR><TD CLASS="quote">No, drum lines and disc lines are not interchangeable. When looking at them, there is an obvious difference. Check it out and let us know..Im like 99% sure.</TD></TR></TABLE>
i am 100% sure they are different.
Old Jun 9, 2006 | 07:59 AM
ludesrv's Avatar
Default Re: (temp)
You NEED disc lines. Either from a CRX if you own a CRX, or a DA integra if you own a civic.
dc5itracer
Jun 30, 2011 01:30 PM
95excoupe
Jul 29, 2006 07:36 PM
sloweredcivic
15
Mar 16, 2005 09:12 PM
Civichatch2k
Jan 9, 2005 07:17 AM
Civichatch2k
Jan 8, 2005 10:22 PM
