oil pan gasket b16
Old Jun 8, 2006 | 08:23 PM
cbabyby's Avatar
Default oil pan gasket b16
i have read many catalogs and talked to many people, should i or should i not use rtv sealant to help seal the oil pan gasket.....jdm b16
Old Jun 9, 2006 | 07:58 AM
cbabyby's Avatar
Default Re: oil pan gasket b16 (cbabyby)
Old Jun 9, 2006 | 09:29 AM
JimBlake's Avatar
I'd only put on a tiny bit. Too much will lubricate & allow the gasket to squirm out of position. The only places where you actually need it are where the oilpump & rear seal carrier join the block. Sorta near the 4 corners of the pan.
Old Jun 10, 2006 | 07:32 PM
sepulchral's Avatar
ONLY use a thin bead along where the block meets the oil pump and the rear main seal hosing/transmission
reuse the stock clean oil pan gasket if its not torn or compressed unevenly, i reused mine w/ 200k mileson it no leak
somick
Aug 3, 2017 08:45 AM
Danethomp
Sep 30, 2006 10:26 AM
ITR-00-1457
Apr 11, 2005 06:26 PM
