Wheel Stud broken
How difficult is it to replace the wheel stud on a 93 accord. i broke one of the studs and feel as if it should be replaced so that i have 4 bolts holding the wheel on....
Front/rear??
Rear are pretty easy, at least on the newer ones I've seen. There's room to press it out & pull the new one in.
On the front, the steering knuckle might be in the way. On my '95 Integra you have to press out the wheel bearing to get the stud...
If there's not enough room for the new stud to go in, take a grinder and grind a little bit off one side of the stud so it'll go in without trying to finess it and messing up the threads.
On my 98 accord it was kinda like this
so i forced it in, screwed up the threads, and got the lug nut stuck on it. Don't let this happen to you
streetracer_305
18
Jun 20, 2015 01:59 PM
FourthGenHatch
13
Jan 13, 2003 03:49 AM
