AUTO REV on a 94 GSR..PLZ HELP!!!
Old Jun 8, 2006 | 12:45 PM
Seth94GSR's Avatar
Default AUTO REV on a 94 GSR..PLZ HELP!!!
Hi, I posted this a while back, but I didn't have any response. I'm having trouble of finding the solution to my AUTO REV. It revs to 2.5 and drops to 800. It does this repeatively. I'm getting really tired of it and it is also causing me to burn a hole in my wallet. Its not the map sensor and its getting vaccum. I sprayed break cleaner around my throttle body along the areas of the vaccums..but the rev didn't drop or stop when sprayed. I check my codes and I receieved 3 and 10. But both of those sensors are fine. A buddy of mine said it might be a bolt missing or lose on my intake manifold...but I'm not sure..
P.S. I REALLY NEED HELP HERE.
Old Jun 8, 2006 | 01:29 PM
Danziver's Avatar
Default Re: AUTO REV on a 94 GSR..PLZ HELP!!! (Seth94GSR)
Double check for vaccum leaks. Thats ususally the culprit.
Old Jun 8, 2006 | 01:37 PM
Seth94GSR's Avatar
We have top and bottom, but nothing seems to change with the rev. I know if the spray gets vaccum/sucked into the vaccum it was cause the idle to drop..Correct?
Old Jun 8, 2006 | 02:02 PM
Seth94GSR's Avatar
This is going to be a great problem...If anyone else has anymore input. I'd appreciate it..Thanks.
Old Jun 8, 2006 | 02:03 PM
non_VTEC's Avatar
there are two plugs that are identical i believe it's the IAC and another plug. Make sure those aren't switched. That would cause an irratic idle like that.
Old Jun 8, 2006 | 02:05 PM
Seth94GSR's Avatar
Default Re: AUTO REV on a 94 GSR..PLZ HELP!!! (non_VTEC)
the iac and the map sensor.which is 3 and 10 when you check the codes right?..They are in their proper places and both brand new.
Old Jun 8, 2006 | 02:21 PM
9000rpms's Avatar
dude...mine did that when my coolant was too low...check your thermostat...mine needed some green fluid, or a new part.
Elmorro_jo3
Dec 9, 2014 03:45 PM
KidAccord
Mar 21, 2013 05:51 PM
jvk
Jan 5, 2008 04:44 PM
bhcvc
May 22, 2002 11:18 AM
