couple lsvtec questions.
Old Jun 8, 2006 | 11:58 AM
xDicktonesx's Avatar
Default couple lsvtec questions.
i was jsut told on the phone that the dome on a usdm itr piston p73 is smaller than the dome on a pr3 piston by rs machine.
i was always under the impression that the pr3 was the flattest vtec piston. then came the p30, then the itr then the ctr.
what i wanted to do wa sometehing a little out of the ordinary. i wanted to pick up ls pistons and rework the valve pockets, then mill the crap out of my head to get the desired CR (11.3:1 or so) im assuming ls pistons would yield the lowest CR, however, valve to piston contact is ineveitable with anything bigger than a CTR cam because non-vtec valve pockets are just in the wrong place.
ls block by the way.
i want to run the flattest piston i can and get my CR from head milling. any recommendations?
also, after the arp rod bolts are pressed in, does teh rod need to be worked over at all?
Modified by xDEFTONESx at 2:26 PM 6/8/2006
Old Jun 8, 2006 | 04:03 PM
nothing?
7mile
Nov 17, 2007 02:26 PM
volcom40street
Apr 19, 2004 02:28 PM
streetlvlhatch
Oct 19, 2003 05:45 PM
b19coupe
Mar 30, 2003 01:12 AM
