D15A2 - Engine Size?
Old Jun 8, 2006 | 10:58 AM
apcwzrd's Avatar
Default D15A2 - Engine Size?
Hi All-
I have a 1987 Honda Civic that has been setting for about 6 years in my brothers back yard with a broken camshaft (caused by low oil) that I want to revive. I have a both a Chilton and Haynes manual on this car but there is conflicting information on what the engine size is. Chilton says that the 13DA2 is a 1500 CC, and a 15DA2 is a 1300 CC. It would seem to me that the first two digits describe the engine size - but both manuals are very ambiguous and conflicting about what engines are which. The stickers under the hood say its a 1500 CC but the engine was rebuilt (or exchanged with different engine?) before I bought it so I am not sure what I really have. I bought a used D15A2 head and had a valve job done and its ready to go in but now I am questioning whether I have the right parts for the engine. I would hate to put a 1500 CC head on a 1300 CC engine - know what I mean?
Any help would be appreciated.
Tom
Old Jun 8, 2006 | 10:45 PM
Mavrick's Avatar
Default Re: D15A2 - Engine Size? (apcwzrd)
the d15a2 is the 1500 cc engine
Old Jun 8, 2006 | 11:04 PM
crxnj's Avatar
Default Re: D15A2 - Engine Size? (Mavrick)
ive got a chiltons right in front of me and it says D15A2 (1488cc) just round it off to 1500cc 1.5litre..
Old Jun 9, 2006 | 07:36 AM
fastoffslow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrick &raquo;</TD></TR><TR><TD CLASS="quote">the d15a2 is the 1500 cc engine</TD></TR></TABLE>
it is..............but it is a 12 valve si
Old Jun 9, 2006 | 07:38 AM
ludesrv's Avatar
Default Re: D15A2 - Engine Size? (fastoffslow)
1.5L engine 12 Valve Si man.
Biggest and most powerful engine that came for that generation (fuel injected, carb is second).
Old Jun 9, 2006 | 08:24 AM
crxnj's Avatar
Default Re: D15A2 - Engine Size? (ludesrv)
D15a2 is not an si engine,, its carbed
D15a3 is the si engine ,,efi
Old Jun 9, 2006 | 08:57 AM
ludesrv's Avatar
Default Re: D15A2 - Engine Size? (Mr.speaker)
It's not called Si, it's called 1500S. That's got the carb 1.5L sucked in there right? It's the save engine. I don't know the codes on those old *** engines tho. But it's 1.5L for sure, 12 valve was the max amount of valves at the time for those engine.
Old Jun 9, 2006 | 09:03 AM
crxnj's Avatar
yeah the d15a2 is 12 valve with a 3 barrel carb,,,,,then there is also the d13a2 which is 1.3litre,8 vavles,and 3 barrel carb
Old Jun 9, 2006 | 11:34 AM
apcwzrd's Avatar
Thanks guys - I thought the 15 in D15A2 meant 1500CC but wasn't sure. Page 1-11 of the Chiltons says its a 1500 CC, but page 3-19 (general engine specifications) lists D15A2 as a 1300 CC. Thats where the confusion came in. Its obviously a typo.
Old Jun 9, 2006 | 11:47 AM
Rex-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apcwzrd &raquo;</TD></TR><TR><TD CLASS="quote"> I have a both a Chilton and Haynes manual </TD></TR></TABLE>
I would say start using the Chilton's as a door stop , or maybe fresh bedding for your hamster.....
Old Dec 11, 2012 | 11:00 AM
seanstoney420's Avatar
I have a 91 civic sedan special edition with a 16 valve EFI d15a2 in it.Did this engine come in this car or was it swapped in by a previous owner?
Old Dec 11, 2012 | 09:07 PM
DCRB's Avatar
pix, bet it's actually a d15b2 covered in grease
Old Dec 12, 2012 | 07:26 AM
NOPE,cleaned all the grease off when I put my new clutch in not too long ago and that's when I noticed it said D15A2 on the block.I thought I had a D16
Old Dec 12, 2012 | 07:27 AM
it's raining right now so I'll go get a pic of the stamp/engine when it stops and post them
Old Dec 12, 2012 | 07:30 AM
4drEF's Avatar
Keyboard Humorist
I'll bet you the D15B2 wasn't offered in 1987 like the OPs car is.
Old Dec 12, 2012 | 07:31 AM
I read somewhere that the D16 EFI head will fit on a D15A2 block so I'm thinking that's what was done cause everything I read says the D15A2 only came with a carb setup.
Old Dec 12, 2012 | 07:36 AM
I also read somewhere that the 91 SPECIAL EDITION CIVIC SEDAN was only available on the European market though I find that hard to believe
tinkertime
Apr 17, 2007 10:04 PM
