Quick Question (easy for anyone with a service manual)
Old Jun 8, 2006 | 10:41 AM
eumoria's Avatar
Default Quick Question (easy for anyone with a service manual)
I have a hatch with a D15B1 and the radiator fan won't turn on when it gets hot and it overheats.
I have a D16A6 head lying around I was wondering what sensor needs to be replaced to fix that? Or is it on the block
Thanks to anyone who can help!
Old Jun 8, 2006 | 10:44 AM
temp's Avatar
Default Re: Quick Question (eumoria)
have you bothered checking the fan relay and the fan motor and the fan fuse.
Old Jun 8, 2006 | 11:06 AM
fireant's Avatar
Default Re: Quick Question (temp)
the sensor is on the back of the block I think.
Old Jun 8, 2006 | 11:07 AM
ludesrv's Avatar
More then likely the relay or a dead fan. Hot wire your fan 9connect directly to the battery) to see if it's good. If it's not, then go from there.
Temp sensor is on back of block.
Old Jun 8, 2006 | 11:12 AM
temp's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">More then likely the relay or a dead fan. Hot wire your fan 9connect directly to the battery) to see if it's good. If it's not, then go from there.
Temp sensor is on back of block.</TD></TR></TABLE>
hahaha when i siezed a fan motor i got some alligator clips n wire, hooked er up, the alagator clips were glowing within seconds. yah, the motor AND the relay were bad lol
Old Jun 8, 2006 | 11:14 AM
ludesrv's Avatar
I've directly connect a fan once...then I forgot to disconnect it and the next day my battery was dead and I had to boost my car.
NOTE: Don't forget to disconnect it!
BlackShingo
May 3, 2010 08:51 AM
zeb1117
Apr 3, 2010 09:33 PM
JDM_is_overrated
May 19, 2008 07:56 AM
Be3LiCiOuS
Jul 16, 2003 04:26 AM
