gsr with b16 tranny
Ok, I searched here and TI, for information, and I apologize if I didn't search right, but yeah. I searched.
What will I need to have that setup completed ?
What can I expect with that setup ? (1st gear speed? 2nd, 3rd, 4th? 5ht?)
People keep saying it would be better than a gsr tranny, but why ? (please explain)
what will lower gear ratios improve ?
Thanks for the information in advance guys...
1st ~ 40
2nd ~ 61
3rd ~ 89
4th ~ 117
5th ~ 153
You will just need a B16 tranny (Y21) and you can use your existing clutch/flywheel.
B16 has a little bit shorter gearing so you will be able to accelerate quicker (depending on tire size).
2nd ~ 61
3rd ~ 89
4th ~ 117
5th ~ 153
What are you looking to get out of your setup? B16 gear ratio will help out all-motor wise, but will also hurt your gasmileage on the highway. If you plan to boost, I'd keep the gsr. Every boosted integra-civic I owned had a gsr tranny in it and it work out real good, even though the gear ratio isn't that huge of a difference over the b16 but a tad bit longer. All you need to switch the tranny over to a b16 is the tranny itself. I guessing you own a integra gsr by your screen name. Everything you have will work, just switch out the transmission. Just make sure you pick up a tranny that coresponds to your tranny, cable or hydrolic so it will be a direct swap. The lower gear ratios in your part will help increase your 1/4 trap, initially improving your times if thats what you are shooting for. Someone else may be able to explain more.
Modified by hondafan62269 at 11:59 AM 6/8/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-N »</TD></TR><TR><TD CLASS="quote">1st ~ 40
2nd ~ 61
3rd ~ 89
4th ~ 117
5th ~ 153
B16 has a little bit shorter gearing so you will be able to accelerate quicker (depending on tire size).</TD></TR></TABLE>
thats about right with my stock poormans ITR / Y1 cable b16 tranny with a 8150 redline
2nd ~ 61
3rd ~ 89
4th ~ 117
5th ~ 153
Jintegragsr97
Sep 15, 2008 01:59 PM
