Rocker Panel Repair/Replacement
So I searched, but didn't come across anything that told how you would go about replacing the rocker panels.
My driver's side one is probably going to need replacing (I haven't taken a better look yet).
Couple pics...
The underside doesn't look that bad. Most of what I can see inside there looks like surface rust. Is there maybe a way to get better access to it to look around some more?
I found rocker panels for $43 + $11 shipping.
Doesn't seem too bad. Are these hard to replace? I can weld. I've just not had to replace rocker panels before.
Couple pics...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">cut, weld, smooth, paint
(watch out for fuel lines!!)</TD></TR></TABLE>
I take it the fuel lines run on that side? That would be fun trying to explain to the apartment complex why their garage is in flames.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deviation »</TD></TR><TR><TD CLASS="quote">
Doesn't seem too bad. Are these hard to replace? I can weld. I've just not had to replace rocker panels before.</TD></TR></TABLE>
where did u find that rocker panel i can find them that aren't rusted out did u buy that for like certifit or some were. i could realy use some. pplease tell me.
any way patch panels are easy just cut out what u need to cut go about 6 inch pass the rusted out spot and piece in the part of the rocker u need i did my quarter panels about 2 months ago.
its not hard just takes patients and remeber u can alway cut more off but u can't just glue on more. start with more than u need and cut as u go. do rush!
they pics are unfininshed but i did finish them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex »</TD></TR><TR><TD CLASS="quote">any way patch panels are easy just cut out what u need to cut go about 6 inch pass the rusted out spot and piece in the part of the rocker u need i did my quarter panels about 2 months ago.
Quite the gangsta lean there. Good tip. Always cut less than you think you'll need and trim as required.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89shithatch »</TD></TR><TR><TD CLASS="quote">finished pics?</TD></TR></TABLE>
These are now REQUIRED. You showed the unfinished now we need the finished ones.
</TD></TR></TABLE>Quite the gangsta lean there. Good tip. Always cut less than you think you'll need and trim as required.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex »</TD></TR><TR><TD CLASS="quote">oo and u never told me where u got the rockers panel from?</TD></TR></TABLE>
You can get them from Cross Canada Parts dot com
http://www.crosscanadaparts.co...=2908
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">I hope you cut more of that off, or else the rust will be back.</TD></TR></TABLE>
Talking to me? I've not had a chance to dig more into that section.
Talking to me? I've not had a chance to dig more into that section.</TD></TR></TABLE>
Yeah, the first pictures still have rust on the metal.
Yeah, the first pictures still have rust on the metal. </TD></TR></TABLE>
Yeah those were taken before I dug out what I did in the last pic. I still have to jack it up and look around some more.
SPORT INJECTION
17
Dec 15, 2005 11:27 AM
tzenisj
Jul 21, 2004 09:37 PM
redwinqs
17
Jul 19, 2003 06:26 AM
