A/C Compressor noises, 97 EX
Old Jun 8, 2006 | 08:09 AM
rarak69's Avatar
Default A/C Compressor noises, 97 EX
Hey, my A/C was low on freon, went to put a can in, only took about half of the can and the a/c compressor whines only when you rev it(clutch engaging) sounds like a huge blower or something.
the a/c would always leak every year, and just refilled it, would usually last the summer.
now it will not get cold or anything, should i replace the compressor, or is it likely theres something else in the a/c system that could cause this.
the belts are fine, and if i do replace the compressor, should i have it proffesionally refilled, or can i use the cans from autozone.
Old Jun 8, 2006 | 09:53 AM
standbackimapro's Avatar
Default Re: A/C Compressor noises, 97 EX (rarak69)
Well if its been leaking and making noises then id replace it..
Old Jun 8, 2006 | 10:47 AM
rarak69's Avatar
Default Re: A/C Compressor noises, 97 EX (standbackimapro)
well it just started making those noises as i tried adding a little bit of 134a....didnt do it before. i was reading up and some people say if its low on freon or oil that can do it???
if i do replace the compressor, should i have it proffessionally refilled then? and not use the at home autozone cans?
Old Jun 8, 2006 | 12:06 PM
maivla01's Avatar
maybe because u didn't add the 143a oil that what causes the a/c compressor to damage. maybe the cluch didn't kick in...well it's my opinions.
Old Jun 8, 2006 | 01:14 PM
rarak69's Avatar
Default Re: A/C Compressor noises, 97 EX (maivla01)
i used that 134a can w/ the oil and leak stuff all in one from autozone.....or less the can was whack????? dunno a buddy's got some proper gauges is going to look at it tomorrow and see if theres a clog or something. he said thats a possibility b4 i drop $$ on a compressor. ill post up w/ my findings.
hatrick
10
Jul 3, 2012 10:30 AM
jdm.coupe3234
May 2, 2010 11:38 PM
lakerschamp2000
May 27, 2009 03:01 PM
ricerodder91EX
Aug 11, 2008 05:30 AM
