jdm gsr-b17 cams which head to get??
I have a jdm gsr block and i wanted to put it together,just sitting. I was wondering which head would be the best to get? I want to go nitrous on it.
JDM GSR BLOCK
B17 Cams
HEad?????
MAybe a stock jdm gsr,b16,itr. Remember i want to go nitrous on the engine so which is better.
JDM GSR BLOCK
B17 Cams
HEad?????
B16A and B17 are the same thing, just stroked.
I'd go with ITR cams. You get enough NA power for when you don't nitrous so that you have a fun daily, but it's not too too aggressive (compared to aftermarket) for when you that that ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">B16A and B17 are the same thing, just stroked.
I'd go with ITR cams. You get enough NA power for when you don't nitrous so that you have a fun daily, but it's not too too aggressive (compared to aftermarket) for when you that that ***.</TD></TR></TABLE>
00+ ITR cams
older are not as aggressive
00+ ITR cams
thanks ill probably just end up going with the b16 cause i already got one. ill post pics when i finish the swap might be a while. THAnKS
is there a difference bwtween the 99 si usdm head vs. the jdm b16 head. internals? if so which would go better with the setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $racer1 »</TD></TR><TR><TD CLASS="quote">is there a difference bwtween the 99 si usdm head vs. the jdm b16 head. internals? if so which would go better with the setup</TD></TR></TABLE>
what jdm b16 head?
what jdm b16 head?
how about specifying the YEAR of the JDM head. i hope you are raising compression on the block if you plan on using a B16 head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $racer1 »</TD></TR><TR><TD CLASS="quote">pr3-3 off a 88-91 siR</TD></TR></TABLE>
a 99 si head would be better in that case.
ugh. 99 head will have slightly better flow. dont use a b16 head unless you plan on upping compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">do i need to say it a third time?</TD></TR></TABLE>
Please do, I love it when you talk dirty.
BTW Nitrous loves 14:1 comp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***-assin »</TD></TR><TR><TD CLASS="quote">
I would go with civic type r intake cam and a integra type r exhaust cam i have a built B18AI ls motor with nitrous at a 175hp shot it is a direct port system if you really want the most out of your car with nitrous have some head porting and polishing done and go with 1mm oversized exhaust valves like fereea i have a guy that does my port work the name of the person is mickey pop his phone number is (828)298-8938 he is the best i have seen and he can also do a valve job he is really cheap and he knows what he is doing so give him a try
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseries!EF!hatch »</TD></TR><TR><TD CLASS="quote">I would go with civic type r intake cam and a integra type r exhaust cam i have a built B18AI ls motor with nitrous at a 175hp shot it is a direct port system if you really want the most out of your car with nitrous have some head porting and polishing done and go with 1mm oversized exhaust valves like fereea i have a guy that does my port work the name of the person is mickey pop his phone number is (828)298-8938 he is the best i have seen and he can also do a valve job he is really cheap and he knows what he is doing so give him a try </TD></TR></TABLE>
fail.
fail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseries!EF!hatch »</TD></TR><TR><TD CLASS="quote">What is your problem temp!!!</TD></TR></TABLE>
you.
you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseries!EF!hatch »</TD></TR><TR><TD CLASS="quote">temp when you decide that you wanna talk let me know i have done nothing to you but we will settle this asap!!!!</TD></TR></TABLE>
what you wanna meet me by the swingset after you get outta school or something kid?
