brake shims came loose and cut my rotor...
Old Jun 8, 2006 | 06:41 AM
M4's Avatar
M4
Default brake shims came loose and cut my rotor...
i installed new brembo rotors and ebc greenstuff pads 2 weeks ago on my accord. ever since then they've been squeeling and making noise while i drove (which i thought was weird as i did the rears a yr ago with the same setup and they make no noise whatsoever). i said i'd give them 200 miles to break in, and hopefully the noises would stop. so i've drivin around 700 miles since the install and the noise has gotten worse. they squeel when i brake and make noise while the car is moving.... last night i finally got a chance to take a look at the front left brakes, and it turns out the shim moved off the pad and toward the middle of the rotor... and it actually sliced my rotor, i'd say about 1/8" deep.
i dont remember using an old shim, so i'm pretty sure the shim was on the ebc pad (can anybody confirm?). i checked the right front brakes, and the shim is also moving, moved about a cm... so now i have a pad without a shim, another with the shim moving, and a sliced rotor about 1/8" deep.
so what do i do now? should i just remove the shims and install the pads without them? should i replace the rotor that's sliced 1/8" all round? buy new pads n rotors again? thanks.
Old Jun 8, 2006 | 06:50 AM
Ross 2.0's Avatar
In a Junkyard near you.
I wouldn't worry about the rotor. But you can replace the shim or leave it out, it's really just there for noise control.
Old Jun 8, 2006 | 07:51 AM
Stoich EG2's Avatar
Default Re: (MooGoCow3)
yeah, don't worry that during hard braking, your rotor could just break.
replace the rotor.
Old Jun 8, 2006 | 04:12 PM
M4's Avatar
M4
Default Re: (ADVAN EG2)
yea, i defenetly don't want it to crack on me. i just ordered a new one. should be here by tuesday.
in the mean time, i removed the bad shims and put everything back together. test drove it, no noise, may drive it some more tonight to see how it sounds.
Old Jun 8, 2006 | 06:07 PM
v4lu3s's Avatar
RTFM
i ahve had problems like that with just about every set of EBC pads i have put on. i hate the shims on those.
Old Jun 8, 2006 | 08:03 PM
Eddiebx's Avatar
that happened to my hawks as well, i just pulled it out and drove anotehr 10k miles problem free
Old Jun 9, 2006 | 03:52 AM
Ross 2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, don't worry that during hard braking, your rotor could just break.
replace the rotor.</TD></TR></TABLE>
Oh yea sorry your right. I guess my experience as a Honda technician is null in this situation.
And how much weaker did this 1/32 of material make a rotor with probably about 12mm of material originally get?
It's not going to hurt anything. I've seen much worse than this before.
Old Jun 9, 2006 | 10:13 AM
globeDELETETHIS USER's Avatar
Shims really dont do much anway, they just prevent noise
canooten
11
Sep 12, 2014 09:39 AM
Landshark68
Apr 20, 2007 10:01 AM
paxorion
Aug 4, 2006 06:30 PM
litterbox
Apr 1, 2005 05:19 AM
