car shakes when idle, speedometer needle "slings"
Old Jun 8, 2006 | 01:34 AM
osuperjohno's Avatar
Default car shakes when idle, speedometer needle "slings"
hello everybody,
my accord shakes when it's on idle, like way more than it should regularly, any reason why?
also, when i accelerate, sometimes i gotta go at least 20 mph for the speedometer to move, and when it moves, it slings from 0 to 20, like a rubber band, any reason why?
thanks for your help everybody!
Old Jun 8, 2006 | 08:42 AM
Iamcuddles's Avatar
Default Re: car shakes when idle, speedometer needle "slings" (osuperjohno)
Ive got the same problem. Sometimes the RPM doesnt work, I just tap the cluster and it works.
Old Jun 8, 2006 | 05:01 PM
bump
Old Jun 8, 2006 | 05:27 PM
hondadude's Avatar
Do you have any idea of what YEAR your accord is?
Old Jun 8, 2006 | 06:33 PM
Default Re: car shakes when idle, speedometer needle "slings" (hondadude)
yea it's 02 coupe lx inline-4
Old Jun 9, 2006 | 09:24 AM
Iamcuddles's Avatar
Mine is a 90 LX
Old Jun 9, 2006 | 10:15 AM
globeDELETETHIS USER's Avatar
I have a 90 Accord and My car idles rough, like its about to stall
someone Suggested to me once a bad Trans mount
But i think it could be the alternator
Do you notice a little bit of a hesitation when you give it gas during idle?
Old Jun 9, 2006 | 10:24 AM
Default Re: (NewJerseyhonda)
yes a little, then it just kinda slings forward (the car) when i accelerate
Old Jun 9, 2006 | 12:47 PM
Dmc1's Avatar
Default Re: (osuperjohno)
do you guy have any cels? check engine lights.
on the one with the speedo problem it could be a weak alternator if you not getting enough volts then the sensor has a hard time working at low speeds.
but I would bet it's the vss going bad try cleaning out your iac and the egr valve on the intake manifold.
Old Jun 9, 2006 | 02:46 PM
Default Re: (Dmc1)
wow, what's all this 'vss' and 'iac and egr' stuff? haha please elaborate
anyways, more specifically, i remember getting my intake manifold opened up and cleaned out a year ago...because i had a check engine line regarding one of teh sensors or something, but now i do not have any check engine light on
for the weak alternator not getting enough volts...i remember my car died because the battery was out 2 months ago, but i went to autozone and got the battery recharged....so do you think it might be the recharged battery that's not good enough?
also, anybody know anything regarding the car shaking excessively during idle?
thanks for all your help guys!
Old Jun 10, 2006 | 12:00 PM
Dmc1's Avatar
The car shaking is probably the rear motor mount.
And get the battery and the alternator tested. a bad battery can cause all sorts of weird problems
Old Jun 13, 2006 | 06:03 PM
Default Re: (Dmc1)
how do i get an alternator tested? is it as easy as getting a battery tested?
Old Aug 14, 2006 | 04:41 PM
mr_carman007's Avatar
Go to autozone they will test it for free
smagic
Mar 23, 2008 01:35 PM
ajth87
Mar 9, 2006 01:49 PM
unhappy_idle
Feb 13, 2006 06:50 AM
Charlescox
Nov 28, 2004 06:39 AM
