No power at low rpm......
Old Jun 7, 2006 | 11:13 PM
lil13wayne's Avatar
Default No power at low rpm......
I have a 92 Civic Cx with a 94 B18B swap with ls tranny and p75 ecu.... i have intake, header, 2 1/4" cat back, underdrive pulley and light weight flywheel. the problem is it seems like its flooding itself out at low rpm's. ive changed the iacv, tps, map sensor and have also reset the ecu. ive changed the o2 sensor as well. i checked the timing and every other thing possible. the only thing i havent changed was the coolant temp sensor which ive heard may be the problem. ive also heard it could be that the map sensor and tps wires are switched. i dont know how the engine ran prior to the swap but it started up with no problems. does anybody have any clue as to what this could be? it runs fine after about 2k rpm's its just getting there it has no *****.
Old Jun 8, 2006 | 05:05 PM
lil13wayne's Avatar
Default Re: No power at low rpm...... (lil13wayne)
nobody has any idea?!?!?!
Old Jun 8, 2006 | 05:20 PM
Flatland2D's Avatar
Not to be a jerk but, are you familiar with Honda's? You know they don't generate torque at low RPM's, right? Almost all Honda's don't start making any power until at least 3 or 4,000 RPM.
Old Jun 8, 2006 | 05:52 PM
matthevelli's Avatar
i just had this problem..i have a hatch with a b16, it had really bad gas milage and didnt pull at all in lower rpms, turns out my tps was installed wrong, make sure its set in there correctly, and your getting a proper reading
Old Jun 8, 2006 | 05:57 PM
Syndacate's Avatar
Default Re: No power at low rpm...... (Flatland2D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flatland2D &raquo;</TD></TR><TR><TD CLASS="quote">Not to be a jerk but, are you familiar with Honda's? You know they don't generate torque at low RPM's, right? Almost all Honda's don't start making any power until at least 3 or 4,000 RPM. </TD></TR></TABLE>
'Tis what I was going to say...might wann ask the dude to test drive it (if u know him), see if it's actinv the same as b4, that might jsut be the way that engine acts...never owned an LS, couldn't tell u, all I can tell u is that my engine usually bogs like that in 5th gear, it's not until ike 3k where it actually produces enough torque to the point where it's normal....which pisses me off, the EX tranny is way too long for the displacement
Old Jun 8, 2006 | 07:26 PM
lil13wayne's Avatar
ive owned quite a few honda's and realize that they have an issue with torque and the fact they have none. but im talking the thing doesnt even want to take of from a stop and stumbles over itself. but thanks for your experience with the tps. ill be sure to check that and post my results. thanks
jtex24
Jul 29, 2015 03:27 AM
chope045
12
Dec 12, 2010 06:36 AM
hondanc7
Honda S2000
Mar 19, 2009 02:10 PM
SIK IN DA HED
Nov 21, 2002 03:21 PM
