reverse light staying on HELP!!!!
Old Jun 7, 2006 | 10:42 PM
hayn420's Avatar
Default reverse light staying on HELP!!!!
i finished my obd1 ls into a 90 hf crx and i was wondering how do i get my reverse light to come on only in reverse and stay off the rest of the time
Old Jun 8, 2006 | 07:45 PM
hayn420's Avatar
Default Re: reverse light staying on HELP!!!! (hayn420)
somebody help me please
Old Jun 8, 2006 | 07:49 PM
C1CRX's Avatar
Traffic signal tech
your reverse lights sensor its on the tranny it has 2 leads a black and yellow if i remeber correctly with bullet connectors just look for it on top or the tranny case i think u remove it with a 19mm wrench good luck
Old Jun 8, 2006 | 08:53 PM
Metal Typhoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayn420 &raquo;</TD></TR><TR><TD CLASS="quote">somebody help me please</TD></TR></TABLE> I came to your rescue.. In the CRX HF it has a signal from the back-up lights to the ECU at pin-out B9, green with black stripe wire - cut the wire in half and tape both sides up..... your problem is fixed.... mine worked... so should urs !
Old Jun 8, 2006 | 08:58 PM
bag's Avatar
bag
Default Re: reverse light staying on HELP!!!! (Metal Typhoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metal Typhoon &raquo;</TD></TR><TR><TD CLASS="quote"> I came to your rescue.. In the CRX HF it has a signal from the back-up lights to the ECU at pin-out B9, green with black stripe wire - cut the wire in half and tape both sides up..... your problem is fixed.... mine worked... so should urs !</TD></TR></TABLE>
yes this is true you gotta cut the wire after you get rid of the stock hf ecu..otherwise it will do what you're saying and its also been known to stall out the car when you put it in reverse
Old Jun 8, 2006 | 10:38 PM
hayn420's Avatar
much mahalos
88CRX951
Feb 15, 2008 08:02 PM
racereaper7
Oct 20, 2006 07:27 AM
shifts
12
Oct 16, 2006 10:36 AM
whiteef-8
16
May 11, 2006 10:21 AM
dawrenn
Mar 11, 2005 08:26 AM
