Timing belt adjustment
Old Jun 7, 2006 | 09:45 PM
davelux's Avatar
Default Timing belt adjustment
I just want to confirm that I did the timing belt adjustment correctly. The vehicle is a 1984 Honda Accord 5pd Manual 1829cc engine code ES2. I am re-assembling the engine following acomplete rebuild.
In the service manual is talks about loosening the tensioner adjusting bolt and then rotating the crank counterclockwise until the cam pulley moves three teeth. It also says that if the crank pully bolt comes loose you need to re-torque to 84 lb. foot.
My question is, should I remove the belt, rotate the cam clockwise 3 teeth, re-install the belt and then brace the flywheel or just rotate the cam and flywheel together as the cam moves the distance of 3 teeth?
I have tried both ways and currently it is set with the latter method as when I tried doing it the other way the crank pulley bolt came loose before I could barely move it a tooth. It just didn't seem to visually do much when I adjusted it the other way.
How much flex should there be in the timing belt when it is properly installed?
Thanks a bunch.
-DL
Old Jun 8, 2006 | 06:51 AM
notoriousB's Avatar
Default Re: Timing belt adjustment (davelux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davelux &raquo;</TD></TR><TR><TD CLASS="quote">My question is, should I remove the belt, rotate the cam clockwise 3 teeth, re-install the belt and then brace the flywheel or just rotate the cam and flywheel together as the cam moves the distance of 3 teeth? </TD></TR></TABLE>
do not remove the belt - this process needs to be done w/ the belt installed to properly tension the belt.
Old Jun 8, 2006 | 03:50 PM
davelux's Avatar
Default Re: Timing belt adjustment (notoriousB)
Unfortunately I had to remove the belt during the rebuild process. I am now trying to figure out the correct way to put the new one on and then set the tension. Thanks for the reply.
Old Jun 9, 2006 | 05:10 AM
notoriousB's Avatar
I meant when tensioning the belt.
giovannie23
Aug 9, 2013 08:30 PM
sukcak
Jul 17, 2008 07:45 AM
god.loves.ugly
Jan 18, 2007 03:44 PM
thunteg
Aug 13, 2004 10:29 PM
Shady Hills
Jul 24, 2004 09:40 PM
