zc with a6 parts?
What you can't do is the reverse - use the ZC tranny *and ZC axles* with an a6 motor. Some people confuse this, and don't care to double check their info.
The dohc zc slips right into the a6 tranny/flywheel. No issue with mounts/axles, since the a6 doen't have an int. shaft.
thanks.....another question.....does the headers works as well....cuz i have after market headers too.....i've been told i might run into problems because of the fact that the zc is a dohc head...so agian...any help?
yea....in the process of the swap...and DAMN I broke one of the bolts into the flywheel...and yea i tired to get it out and failed.....SO NOW....i have to use the zc flywheel with the a6 clutch....any problems with this?.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi »</TD></TR><TR><TD CLASS="quote">yea....in the process of the swap...and DAMN I broke one of the bolts into the flywheel...and yea i tired to get it out and failed.....SO NOW....i have to use the zc flywheel with the a6 clutch....any problems with this?.......</TD></TR></TABLE>
if you can bolt the pressure plate to the flywheel, yes, the ZC flywheel is the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi »</TD></TR><TR><TD CLASS="quote">thanks.....another question.....does the headers works as well....cuz i have after market headers too.....i've been told i might run into problems because of the fact that the zc is a dohc head...so agian...any help?</TD></TR></TABLE>
your header will bolt up, however, the ports in the head won't match the header - you will need to grind out a little at the top of the header to match ports in the head
picture of ZC exhaust gasket on SOHC D-series header
headers will work but the ports are lightly off.. i have a dc header on my dohc zc and it runs fine with the header but im takin them off this weekend and just slightly porting them out a lil
91 ZC hatchback
Dec 28, 2005 08:37 AM
h22_crx
Aug 30, 2005 05:59 AM
