help with conversion from auto to manual, check the pics out!!!!!!
hi honda tech member dudes, doing conversion from auto to manual, but i took some pics becuase in not sure if this is okay or what, if some could tell me if there is something wrong or if its okay. here are some pics of the clutch pedal, i kind of think that the clutch pedal is a bit to much in the front of the rest of the pedals, info, input, anything i could use!!!!
Looks fine...
There should be a bolt that you can adjust to remove some of the play and push the pedal deeper into the foot well...
I loved doing my A-M conversion...sigh... ahhahaa Good luck with it.
There should be a bolt that you can adjust to remove some of the play and push the pedal deeper into the foot well...I loved doing my A-M conversion...sigh... ahhahaa Good luck with it.
