Ecu tuning
I want to tune my ECU on my 92 accord (F22A1) i was curious to know what other people had for setups... i was thinking a hondata setup or an uberdata, but has anyone ever used a greddy e-manage? any input would be awesome. thanks.
Phil
Phil
i was at ecutuning.com and i could pick up a P06 chip and a PO6 ecu and toss that in my accord... i saw the p28's but they were all tuned for like integra gsr's and just setups that i'm no where near
Yeah use a p06. it's the same damn ecu as a p28 it just doesn't have the vtec feature..If at some point you do an h22 swap or build a g22 vtec hybrid you can just go to xenocron.com and order the vtec conversion kit for it for like 20 bucks.
Emanage is garbage for tuning. crome,neptune or uberdata will do you much better. emanage is just a piggy back it intercepts the sensor signals before they get to the ecu and then modifies them,fakes out the ecu into thinking everything is fine.You don't want that type of system it based on a lie when you can just reprogram your actual computer to deal with the real data from the sensors like larger injectors or boost from a turbo. when the last time you had a lying girlfriend not f you over and waste your cash while blowing up your life.cars love honesty just like you do
check out pgmfi.org for more info.
I'm just curious why do you need to tune your ecu. those ebay chips you can buy don't do anything except dump more fuel and waste your gas milage. or something retarded like move your redline to 8k so you can blow your motor
Yea something along those lines. What im gonna do is retune mine whenever i got the time with uber if not crome. But yea I have an ebay chip and it makes your run hella rich (skunk2 ebay style) with the raised *9500* rpm redline which I think its the suck but yea.
wtsapexipowerfc
Engine Management and Tuning
Oct 2, 2010 06:47 AM
NatedoggAZ
Jul 31, 2003 05:01 AM
