jdm fuse diagram
i was suprised i could'nt find this in the search, so was wondering is your US model the same as my '97 jdm & if so could someone post the english version for me or point me in the right direction
tanx
i'll settle for a pic of the usdm version for comparison if no one knows whether they're the same as jdm
tanx anyway
tanx anyway
right, must have had my international translator turned off
is there any chance someone could scan & post this fuse diagram for me PLEASE
from your US model itr as you can see mine is in japaneese.
Uncle John! How you doin!
(Just kidding, no relation)
http://www.integra.orcon.net.nz/fuse
Below on the left is a diagram of the fuses located in the drivers side kick panel, the descriptions of each fuse is written in Japanese so here's a translation. I should also say that I can't read Japanese so for all I know it says "If one of these fuses blows, you're screwed" but I'm sure the translation is more or less correct. On the right is a diagram of the under hood fuse box, located on the driver side of the engine bay. The two 50 amp fuses are for the main front and rear lights.
1) 5AMP: Remote pole, Air refiner
2) 20AMP: Right front power window
3) 10AMP: Right headlight low beam
4) 10AMP: Left head light low beam
5) 15AMP: Power door lock
6) 20AMP: Left rear power window
7) 20AMP: Left front power window
8) 20AMP: Right rear power window
9) 10AMP: Right headlight high beam
10) 10AMP: Left headlight high beam
11) 15AMP:Tail light, Meter light, License plate light
12) 15AMP:Cooling fan
13) 10AMP:Remote Control Pole, Rear fog light, Auto Antenna
14) 15AMP:Clock, Interior light, Cigarette lighter
15) 20AMP:Sunroof
16) 20AMP:Wiper/ Washer (Power window/ Sunroof)
17) 7.5AMP:Rear demist
18) 7.5AMP:Starter signal
19) 15AMP:Front fog light
20) 15AMP:Condenser fan
21) 15AMP:Cooling fan
22) 10AMP:Radio
23) 10AMP:Backing light, turn signal
24) 15AMP:Altenator
A) 7.5AMP: SPARE
B) 15AMP: SPARE
C) 10AMP: SPARE
D) 20AMP: SPARE
X) 40AMP: Heater motor
Y) Fuse puller
Z) "Do not replace fuse with tin foil or wire or a fuse higher than the specified value. Failure to heed may result in faulty electrics or a fire"
All taken from https://honda-tech.com/zerothread?id=1344868
Hope that helps ya out. Now send me some green beer.
tanx for that mate, most of the itr's here are jdm, i've only seen 1or2 euro itr's in passing so i'd no other way of finding out
tanx again mick.
tanx again mick.
Vagitarian
17
Jul 30, 2012 06:56 AM
danielfleenor
Nov 17, 2009 01:50 PM
import-tooner
May 28, 2003 07:37 PM
