Toda heavy duty oil pump B16,B18, B20
This toda oil pump gear goes into your stock oil pump from any b-series. i am asking for $200. you can see in on the toda website and that it sells for over $480 so $200 IS a good deal.
HEAVY DUTY OIL PUMP
The heart of the engine is the oil pump, so when modifications are carried out the oil pump should never be overlooked. Improved oil circulation helps to prevent your modified engine from incurring expensive rebuilds. (Ø80mm or ø84mm) The original equipment Honda B-series engine oil pump gear is a sintered unit and prone to fragmentation at high rpm. The Toda Racing oil pump gear is machined from billet. Toda Racing strongly recommend the use of this product in any engine to be used in a racing application or will exceed 9000 rpm.
HEAVY DUTY OIL PUMP
db1love
Dec 8, 2010 11:27 AM
